1/12 RS12G Atsushi Hara Replica
#601
Originally Posted by mikecatts
Hi all.
If u put more pressure on the side springs via the screw..isnt it the same as adding a stiffer spring?
#602
does anyone know where i can get a setup sheet of hara's car?And if i have a rep.of his car am i suppoesed to have a t-bar?
#603
HARRA PROTOTYPE
Hi all.
Ive been playing with the Harra chassis layout. trying to stiffen the side to side action...(the corally springs are not stiff enough for me).
I tried to use vcs springs..but they are not too good as when you cut them down..you end up with a spike,,I cant seem to get it flat after cutting..(like the original springs),,but what ever I do,I cant match them..wasted a few springs trying this out.
Any one know a spring maker
i used a couple of old trinity 1/10 pan car side Shockers.
moved the body post to fit.
It works excellant, as quick as my CRC3.2R..and it has the fibre glass chassis!..still a few modifications to do..then ill cut the carbon..im gonna use 2.5 mm.
the "NERF" bars will be carbon fibre..and the front bumper will be 2mm lexan. mounted on a modified 190mm touring bumper supprt..they work a treat.and light.
Our local track is very high traction. indoor ashphalt.
Ill keep u all posted,,,it has not changed the general handling..just made it more rigid..suite for high tracktion.
mike
mike
#604
pics
oops files too big
#605
Can someone give me some advice on how to get my AH-12 to launch straight. It always seems to pull to one side. Tweak is good. Diff is smooth. Left and right wheel spacing is correct. Any input?
#606
You might want to check to see if there is anything wrong with the rims and tires!they might have alittle tweak in them!!
#607
also check your tire size. they may be different sizes. that is what happens to me sometimes.
#608
oops files too big
Hey man these are some nices pics!never seen anything like this so now im lookig at mine thinking how the heck can i get mine this nice?Could you send me a list of mods that you have done to it?!!
p.s what the heck are on your batteries they look nice!
#609
still waiting on if i am suposed to have a t-bar with my Ah12 rep?!!
#610
#611
thanks man i ment rep as in replica sorry bout that!!
#612
does anyone have a setup for the L3 front end for med-high bite carpet
