1/12 RS12G Atsushi Hara Replica
#331
I am going to try the CEFX frontend and see how it works.
#332
Originally posted by JDXray
I have had a reflex 12, but i havent used the front end on the hara. I would presume that you can use any front end you want. The reflex front end can be a pain sometimes with all those turnbuckles, but i hear that the reflex front end is one of the better front ends.
If you ask me, it doesn't really matter which front suspension you're going to use.
All three are very good, the AE style, Trinity and the CEFX.
I don't think it will improve your laptimes that much, it's just what you prefer.
#334
thanks guys,
yeah, i know the reflex front end can be a little more work to set-up plus maintain (ball cups). i was just looking at how i could get a lower profile front suspension for lower bodies, ie. CEFX.
if anyone has access to some CAD and a CNC machine who can mill out a thicker hara chassis, depending on price, i'd be interested in purchasing one.
is there an interest out here on the forum for a thicker hara chassis? perhaps if i can get enough of an order put together i can have one of my contacts set up a machine to do the job.
#335
Todd, you dont have a Hara? DO you?????
#336
Originally posted by Electro-MAX RC
thanks guys,
thanks guys,
#338
OOOOOOOOOO
OOOOOOOOOO
#341
penguin chassis
Hey guys,
I've been running a Hamer12 for the past few weeks now, and have been pleasantly suprised how well it works on carpet (even with the flexy chassis)
However, if any of you guys happen to talk to penguin about making one, I would also be interested.
#342
thanks guys,
thanks guys,
There's one!
#344
Re: penguin chassis
Originally posted by biker
Hey guys,
Hey guys,
#345
ok, here goes:
Jaco Purple fronts - 42mm
L4 front end
0 toe in
1.5 neg camber
1 + 1 shim
Copper center spring
40 wt oil
I just put a little drop of bushing lube on the damper disc to smooth it out.. (a VERY litle drop)
CRC lowered bulkheads
Black side springs
Jaco Pink rears - 43mm
That seems to work pretty well for me!
L4 front end
0 toe in
1.5 neg camber
1 + 1 shim
40 wt oil
Black side springs
