BMI's DB12R
#7967
Can happen if you put 0.5 (maybe even 1.0's) ride height adjusters in the motor pod the wrong way up
I did a few years back and because it was lower on one side it pulled that way
#7970
Car was thundering today at the qualifying rounds, but so was the sky, and we got rained out. 3rd qualifying round and finals 2mz
We officially voted in 1S Lipo for 1/12th, so I need some help. We only run Modified class 1/12th and I wanted to check which receiver pack I should get and how long they last. I see stormerhobbies has a SMC 450mAh 7.4v 20c??
Obviously using a BEC... any suggestions from experience...
Also, which 1S Lipo?? SMC has a 50C 4900, Epic has a 40C 5200. What would be better for Modified??
Do you find you need to use a lower turn motor to get the speed or is the gearing cranked up, if so how and to what???
Thanks in advance!!!
#7972
SMC receiver pack is big. I bought it but never installed.
I run 4.5 with rollout 8-10mm higher than 4 cell. I don't have run time issue with Novak smart boost but yes it's little bit soft.
Little black pack next to SMC pack is 200mAh receiver pack I used before I changed to Booster. Takes about 80-120mAh per 8min run.
My Novak booster fits under servo with bit of rewiring.
#7973
Attachment 510765 Attachment 510766
We also plan switching to 1S in modified, just want to know what gear I need to get to keep up with 4cell + 5.5T brushless. I don't see myself charging 2 packs (main pack + receiver pack) after every run, so I would probably sacrifice a bit on power to be able to use only a booster.
P.S.: yeah, that SMC receiver pack is HUGE, I don't know who is this product for..?
#7975
OK so which 8-32nd screws are 80 degree heads? I need some shorter ones then the IRS and don't feel like cutting them down. I ordered a couple AE ones knowing some are 100 and some are 80 and ended up with both as 100.
#7976
From what you are telling, sounds like you could even go with 4.0 or 3.5 with 5000mAh pack..
#7979
#7980
