BMI's DB12R
#6677
rollout
i recently purchased a DB12r ive got an lrp sphere esc and lrp 17.5 motor and according to lrp the roll out should be 68mm should this apply to all tracks regardless of size . i know there are several pinion/spur combos to get the roll out so do i use small gearing for small tracks and large gearing for larger tracks or run the same gearing set. This is my first year running onroad/electric racing so im trying to get as much knowledge as i can
#6678
#6679
Moderator
I have a question about front droop. I am not seeing much at all droop running the .20 Linear springs in a setup matching yours Jason that you just posted.
What is the recommended way to measure droop on the front and back?
I am giving the car a run tonight with your setup ( my old setup was the servo up on an angle, and pretty much the box stock config), so this is quite a large change in setup, we'll see how I fare
#6680
How do you apply silicone oil?
Hi
What i mean is do you only apply to the grooves or totaly cover the rod with oil.I have only been told to use the grooves only,But just would like to know?
#6681
Moderator
Umm what are you referring to? The kingpins or the damper tubes? for Damper tubes I just put a couple drops on the end of the tube, and then move the damper shaft in and out a few times to distribute it around. For king pins... I am not sure what grooves you may be talking about.
#6682
#6683
#6684
Moderator
yes. I dont use the brass shims, i use smaller shims so I can tune it a little more.
#6687
Moderator
So I took jasons setup nearly exactly and tested it out today. I played with Camber and toe a bit on the front and didnt have 20,000 weight but I had 30,000 so I used that.
The car was very consistent, not as numb as before. Even turn-in and power out of corners, no real snappy over steer. Quite nice and fast. I didnt hit my fastest time on the track (10.1) that I set last weekend. But I did run a good number of laps consistently in the 10.2 - 10.4 range which is a big improvement.
The car seems easier on the tires now by a good bit... I had no issues with uneven l/r wear, or ballance issues.
Cant wait for race day
I did find neutral toe was the way to go on the front, I tried a degree or so neg and pos and both slowed the car down. and I am running between 1.5 and 2 negative for camber (still testing).
I coated the front kingpins wiht the 30k weight above and below the lower pivot ball and that smoothed things out quite a bit up front.
#6689
Whats your whole setup?? Maybe we can help you dial it in a little more. 30k is bit much, I think. The most I use is Red Sure Lube.
