BMI's DB12R
#3362
The flex plates do not need to run the set screws. That is a tuning option used for various spring rates without changing plate thickness. There is no tweak to the flex plates. There is a slight bit of preload on them that create a slight dead spot off center but is in no way tweak. There is no possible way for it to tweak without breaking something due to the way it is constructed. The standoffs where the flex plates mount to are identicle to eachother and this mounting height ensures that the tweak is perfect. If somethings is bound up during assembly it can become a little off so you need to make sure everything is free and there is no binding. Hope this helps.
#3371
[QUOTE=protc3;3984787]Shipped out today buddy. It will be there thursday.
#3375
We are making it a 200mm pan car to run with 1/10th pan car foam tires and HPI 200mm bodies. We are still deciding on the bodies to run on them but are leaning towards the real car style bodies. It will be a great alternative to TC by having a less complex,better handling car for alot less money. The pan cars of today are of much higher quality than past years and with the right direction can make a comeback. TC is just getting way out of hand as far as complexity for the average racer. With a car like this we can get more people into the onroad scene with a lower street price,exceptional performance and low maintanence.
