BMI's DB12R
Old 07-20-2007, 08:44 AM
Mr. Shookie's Avatar
Default BMI's DB12R
I know there is a 12th scale forum but with the popularity of the new BMI DB12R, I thought it would be nice to have its own thread to ask questions and have Owner/driver and Team drivers answer them without going through pages of the 12th scale forum.
As far as I heard the release of the new car hits at the end of this month.
Here are a couple pics of mine, but mind you the new car has the new easy access for brushless motors.
Here is a link to what yours will look like with the standard rear pod....
http://bmiracing.com/images/Link%20collage.JPG
Jason can you throw the updated pics on here?????
Thanks for an awesome car.
So post up your questions....
-Shookie <><
Mr. Shookie is offline
Old 07-20-2007, 09:03 AM
Found the pic of the production car...
http://www.rctech.net/forum/attachme...1&d=1184893881
Hope that helps,
-Shookie <><
Old 07-20-2007, 10:50 AM
SlamMan's Avatar
Can't wait! This will likely be my first 1/12th.
SlamMan is offline
Old 07-20-2007, 10:52 AM
annie_himself's Avatar
I never knew BMI had there own 12th scale. Looks good.
annie_himself is offline
Old 07-20-2007, 10:56 AM
Trader Rating: 11 (100%+)
Hey guys... we have some video of the car on episode 705:
http://www.rctvlive.com/
RCTVLIVE is offline
Old 07-20-2007, 06:12 PM
protc3's Avatar
Trader Rating: 13 (100%+)
everything is looking good with production and we should be on schedule for the expected release time frame.it will be late august for the car and full parts support.i will answer all the questions about the car that you guys may have.
protc3 is offline
Old 07-20-2007, 08:24 PM
aca
Jason, what servo mounts will the kit have or do we furnish our own? And will there be a setup sheet for asphalt with the kit?
Thanks, Allen
aca is offline
Old 07-20-2007, 08:30 PM
protc3's Avatar
i am developing new servo mounts that will allow you to run the servo flat or angled.the car will come with my asphalt setup and the carpet setup we used for testing.both setups work extremely well.i will put together some pics tommorow to go in depth with an explination on our new rear suspension system.it is very unique and is extremely durable.my car has not seen a tweak station since february and is still tweak free.
protc3 is offline
Old 07-20-2007, 08:39 PM
CarlosG.'s Avatar
Trader Rating: 12 (100%+)
Jason, will you be offering bot thicknesses L-plates for the car so one can use the car on both surfaaces, or offer them seperate depending on the time of purchase which is wanted due to the surface the owner will be using the car on?
CarlosG. is offline
Old 07-20-2007, 08:48 PM
AdrianM's Avatar
Jason and I have been doing most of the testing so I can answer this one...
We have found the thick plates are best EVERYWHERE.
Keep in mind that the normal t-bar thickness rules do not apply to this car because the fore and aft movement is on pivot balls.
On a t-bar car you always have to compromise steering vs. rear traction when you choose the t-bar you want to run.
The DB12R lets you run stiff flex plates to get you loads of steering but this has zero effect on rear traction because that is governed seperatly by the rear shock and spring.
All this steering lets you run less dual rate for less tire scrub, more corner speed and less tire wear.
AdrianM is offline
Old 07-20-2007, 10:31 PM
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey Guy's I got the privilege to try out BMI's db12r Throught a friend of mine here's a brief report on the car. I was very impressed with how easy and effortless the car was to drive.
You don't have to push this car at all to make fast laps Its very easy to drive.The dbr12r is fast right out of the box awsome!!!
And the first thing I noticed about the car was how fast the car cornered and how much more consistant it was all around the track ,For as High tech the car is its very easy to setup and work on which is a big plus in my book.
And if ya get to look at one up close the fit and finish I by far the best I've seen. I cant wait to get me one, Anyone thinking about getting this car this car is the real deal The BMI db12r gets my two thumbs up.
mike ivy is offline
Old 07-21-2007, 03:22 AM
protc3's Avatar
thanks adrian for that explination.he is correct.adrian and i have been alot of asphalt testing with the car and found out alot of what works and what does not.i will be making different size plates for those who want them but we have had the best luck with the thick ones.
thanks for the feedback mike.im glad that i have been able to get constructive,unbiased feedback on the car.all 3 of you have been extremely helpful. all the help is much appreciated.
protc3 is offline
Old 07-21-2007, 06:49 AM
Can we get some set-ups from Adrain, Jason and the Team, please? Please make sure that you say what the surface and additive is, because we run Jack exclusively in Europe, so need to know if the set-up is for Jack or Paragon, and what surface or carpet type and bite level. Thanks in advance.
SlowerOne is offline
Old 07-21-2007, 07:30 AM
sportpak's Avatar
Trader Rating: 26 (100%+)
Any idea what this cars street price will be? I hope it will be competetive with others. Car looks sweet and I'm in need of retiring the L4.
sportpak is offline
Old 07-21-2007, 08:11 AM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
$250.00
Originally Posted by protc3
i did set a price on the car but i forgot to tell her.the price is going to be 250.00.
Marcos.J is offline
