Speedpassion Brushless.
#842
does anyone have any specs on the 13.5 motors that are out now ? I understand there's two versions ?
#843
Schumacher USA is bringing in ONE version, and the first load of them has been running fantastically all around the country. We've worked with them on the design/performance a bit before they were good enough to bring in
Part# SPF135.
Available through dealers right now, with many many more on the way very soon.
Part# SPF135.
#844
offroad settings
What settings should I run for 1/10th 4WD offroad 13.5 BL/3800 Li-Mn on medium sized clay track: changeable grip (good to slippery/dusty) ....?
#846
Shawn and I agreed that 3.0 is the absolute lowest that you should have it set at.
(which neither of us recommend by the way)
I said #5 which i believe is 3.2?? only because its ALWAYS better safe than sorry.
My goal is not to extend per say, but make sure you can utilize the entire life-span of your battery, and that one of our products isn't the reason its been cut short.
If your solely using this battery/speed control combo for racing, it won't really be an issue because even in practice you normally will only run 8 min max at a time, and the cutoff voltage wont even come into play...normally
#850
i missed this, i ran mine in a b-4 last week with a 13.5 core 5000 lipo, i just used the same settings as i did in on road, i'm so rusty at off road it wouldn't have mattered, but for a 4wd i would think the settings posted earlier would be good to start with.
#852
the GT does not come with the cable, only the motors do, however you can order a cable, they sell them alone
#854
oh i don't know, a page or two, basically punch on 6, timing on 18.75, brakes where ever you think.
