Speedpassion Brushless.
#721
R/C Tech Elite Member
If it is enabled, to comply with current "Roar" rules all of our speed controls are set to engage the thermal protection at 180 degrees. That point is set for the speed control, not the motor.
Does anyone know what temperature the SP GT will use the over-heat protection? I noticed that you can either enable or disable the over-heat protection. Mine will be enabled, but it would be good to know the temp. I would also assume that the over-heat protection is for the GT and not the motor.
Thanks...
Thanks...
#722
What's the different between the Super Sportsman 9.5R and the new Feigao Series 9.5R?
Sorry if it been asked before but I couldn't find much info on their website.
http://www.speedpassion.net/
#723
Tech Legend
Trader Rating: 51 (100%+)
You mean ROAR has a temperature rule on what the speedo needs to shut off at?
#725
Tech Legend
#727
I have mine soldered to the top, Shawn has his soldered in the holes, and i know a lot of guys are using the solder tabs that can be purchased separately, part number SP162810, have you hobby shop get some of those on order....they're awesome and fit tons of motors.
#728
Just a note on temp ..in the instructions it says to mount fans on the motor.So im going to use the team tamale fan mount and run two to help keep it cool.
#729
There is no ROAR temp rule. Most racers run with the temp cut off disabled. Nothing is worse than being in the lead on a hot day and having your car stop. That used to happen all the time with the early Novak bonded rotor stuff...until we learned to pull the blue wire out of the sensor plug
#731
I hope you don't feel like we abandoned your question but were not going to carry the "9.5" motor, there's not class that allows it, ROAR or no ROAR, 10.5 is the standard as of right now and were focusing on that class along with whatever motor ends up being the "new stock class" 17.5, or 13.5
and we'll never forgot you speed demons that need Mod
