Truggy Tires
Old 07-12-2007, 08:10 AM
Default Truggy Tires
I have a truggy and the tires that came on the Kyosho have small nobbies. I need help, the truck is ALL OVER the track. I mean I can't make one good turn.
What kind of tires should I be running the smooth or the fat MONSTER type tires. Any brand or model recomended would be greatly appreciated.
Thanks, Bhard888
Bhard888 is offline
Old 07-12-2007, 08:24 AM
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
You could try checking with the local racers and asking what they run.
Its hard to give advice not knowing the track conditions.
Although Pro-line Crime Fighters or Bow Ties are the standard at a lot of tracks.
Good Luck!
thecman26 is offline
Old 07-12-2007, 09:01 AM
That is the best advice.
You are at the track so ask someone. They will tell you what works on THAT track. The good thing about truggies are that they are more tolerant of tires than buggies are. Panther has a nice line of tires as does GRP.
If those Kyosho tires are from the stock ST then they are only passable at best but you need to use a firmer foam because the stock foam is to soft so the tire flexes a lot in turns.
AreCee is offline
Old 07-12-2007, 10:43 AM
Default Duh
Sorry I failed to mentioned track conditions. The track is hard as a rock and made of sand and is never watered.
Bhard888 is offline
Old 07-12-2007, 01:57 PM
beast95451's Avatar
Trader Rating: 13 (100%+)
Proline Holeshot MTR's as long as its hard pack & not loose on top, those will be your best choice IMO. Or GRP cubics...which i recently found worked great on a hard pack track thats a little dusty & loose on top when not watered.
beast95451 is offline
Old 07-12-2007, 03:45 PM
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Talking
Hard as a rock and never watered!??? GRP CUBICS/ Sand? Even Better. My home track is the same way. At first I ran the GRP GRIPZ which were pretty good. Then I switched to the CUBICS and they were awesome.
Brad S. is offline
Old 07-12-2007, 04:05 PM
Suspended
From the description, it sounds like an MTR(I'm guessing this is similar to M3 compound?) compound Bow Tie would be optimal. I'm guessing the track might blue groove at certain points, creating a good environment for Holeshots but to be safe in the sandier parts (if this is the case), the Bow Ties would dig a bit better.
Nay0k is offline
Old 07-12-2007, 04:24 PM
Wolverini's Avatar
Trader Rating: 41 (100%+)
The only thing controvercial in that is the MTR suggestion. MTRs are great for ripping down the straights but a MT w/ some good molded foams like Ofna orange for example can rip down the straights AND rip through the corners while the MTRs go sliding out of control with less of a side grip. All of this depends on your style of course like whether you power through a corner or coast around under minimal power to maintain grip. Typically from what he describes I'd suggest moving to a crimefighter for starters and maybe Bowties if the track is not as technical and doesn't have as many sharp turns. End result is that a CF w/ soft compound can take the minimal amount of bluegroove and still be able to gain some ground in the looser stuff and sand.
Ask the guy standing next to you in the pits what HE runs and then ask the next 4 guys you run into. You'll soon find out what the best tire to run is at YOUR track and not ours.
Wolverini is offline
Old 07-12-2007, 04:46 PM
Suspended
Wait, I thought MTR was a tire compound, but it's a foam compound? I wouldn't know, I've never owned a truggy before. Guess I'll take a look on the website...
I usually use the orange OFNA foams on rougher tracks myself, though.
Nay0k is offline
Old 07-12-2007, 05:12 PM
Wolverini's Avatar
MTR is an entirely different tire with different features.
