GRracing Modified engine
#46
Hi,
I look at the engine and saw On the combasion camber (underhead) is a notch/scoop . But I am not sure that is in right way installed. Should the notch look to the exhaust port or to the near the carbroteur. I can not remember how was it??
thnx
thnx
#47
It is direction carburetor.
Thanks.
Thanks.
#48
REX RT12S5CH Ver.Team Modified
Technical Data
Displacement : 2.09㎤
Maximum Power : More Than 1.67hp
Bore : 16.26mm
Stroke : 16.80mm
Ports Nr : 5
Piston Type : CNC
Crankshaft : 11mm
Crankshaft Type : Turbo SG
Glow Plug Type : Turbo
*Crankshaft Hard Coated + Full Ceramic Bearing(GS5 Class)
Bore : 16.26mm
Stroke : 16.80mm
Ports Nr : 5
Piston Type : CNC
Crankshaft : 11mm
#49
Are you fooling people around?
Edward
#50
Hey handpiece. I read you post and it is ammesing number you pull out from engine-1.75 ps (I guess ps is stand for HP) . The only thing is bothering me how did you determinate there was over 1.75 ps if you don't run on Dyno? What was createria to get that number? Lap time? Sound level? ... Marketing?
Edward
Edward
#51
Edward
Edward
I thing, I can agree handpiece spec's. I have the Gr racing OZ TZ team version . And I have a OZ speed spec II. too. The Gr racing Oz Tz is a litte bit faster than the spec II. I tested both engine with %16 fuel and ospeed 1040 pipe. Same car gearing etc...
If the ozspeed engine specs on the website is right( 1.7 hp) I can say that the Gr racing engine is about 1,75 hp. I have with the Gr racing engine about 0,1-0,2 better lap times . Our local track is large european style track!
But this not a dyno test. But for me is the best test on the track.
#52
Hi Edward,
If I got your idea right that 0.1-0.2 secomd on laptime is equal 0.5 HP? Is that right?
#53
of course not! I can only say (this is only my experience) it is faster than spec II . The specs from osspeed is for me only a start point for a comparison. maybe ,the gr engine is 1.80 hp or 1.71 hp???
#54
#55
Hi Handpiece
How often did you guys change the conroad? The conroad is a little thin than the original because of the modification. thatswhy I am worry about my conroad life. Pls let me now
ps. You have a pm
thnx
ps. You have a pm
thnx
#56
so i changed OS conrod Per 1 gallon(4 liters)
#57
#58
#59
