ESC forum
#467
Ultimate Hobbies also carries the Keyence Zero V Extreme for like $179.99. They may also carry the other models as well, you will have to give them a call to find out. Ultimate doesn't have a listing on their site for the Keyence speedo but it is listed in their manufacturers listing on the first page. I saw it advertised in RC Car Action. Expensive but still cheaper than what I paid about a year ago!
#468
NEW ESC in the USA!
I've been following this thread for a couple of months.
Here's an early anouncement:
My company will be introducing a new high performance rc racing speed controller in (30 to 45) days. I will update you as to it's street price and specs as soon as everything is worked out. For now here's a picture of it.
#469
hmmm......What is the name of your company? What else do produce for R/C? Is this your first ESC? Give us a little history.
I'm curious.
Wailin, I saw the ad for Ultimate. So far that is the lowest I've seen. Gonna have to go with that so I an get some set-up time with it before the Snowbird. Thanks.
I'm curious.
#470
Originally posted by Alvin
Looking forward to hearing from you. Got drivers in singapore using that ESC for very good results. But don't take my word i'm still green behind the gills
I tried it yesterday and it's mental!! the power is fantastic as with the adjustability. The run times are longer than the Mtroniks Sprint and even longer if u chose a low torque setting.
It makes such a difference, it's quite amazing! buy it!!
#471
TCRboy.... XC where did you find it???
Failing that I am waiting for the MRT VX pro.... it is 100% water proof (unlike my LRP F1 Pro which wnet bang last week!) and very programmable... and no pots to turn....
For anyone in UK, check out Keence in Apexmodels... they got a few left at disocunt.... anyone know what they are like???
#472
Earlier on this thread they were saying the Keyence had amazingly low voltage drop - so should be very efficient.
Someone had one at my old club - pretty small, said "hello" on the LCD screen when you turned it on, and displayed the units temperature while it was running!
#473
#474
Well, I've got a Zero X-treme on the way. Anyone have any tips on programing it?
#475
TCRBOY...
at least you can qualified!!!
#477
this is a very good esc. the adjustability is tremedendous. it even comes w/ pre-programmed profiles. in regards to how to program it, it is very simple and the instructions are very clear in explaining this. first, you need to determine which kind of driver are you - choppy, torque or smooth. there is an adjustment for frequency (not in the transmitter/receiver sense), the lower the value, the more on/off feel you get. the higher the value, the smoother it feels under acceleration. i have mine set @ about 7.1 (i think baseline is 4.5/the higher the value, the greater the chance to overload the esc. i believe keyence recommends staying below 9.0). there is also a drag brake feature (which i don't use), current limiter (not necessary for stock), drive power & brake power (used for fine tuning throttle and brake response). i'm sure there is something else i'm leaving out, but i just can't think about it.
stika525, feel free to leave me any questions that i can try to help you out with.
#478
Originally posted by Disaster999
anyone used futaba 3PJ for the cyclone tc? does it work for the "worlds" profile?
i have to switch it to the stock or high traction to get the esc to work!
or vice versa, i can't remeber. lol
#479
Regional Moderator
Originally posted by Jack_L
Hey, I use the 3pjs with my Cyclone TC2, and everything works fine. I notice that I have to reprogram the throttle and brake after i switch to a new profile.
sigh..dont have pit wizard!
#480
how is USD 174 for a keyence v zero extreme ... am i gettin a good deal???
the hobby shop said it retails at USD 290 ...... is it true???
i m stuck between the GM v12 XC and the keyence
GM is at 145 USD
GM is at 145 USD
