knuckle and steering rod height shim
hi! dude..
i have a question about steering rod height shim connected knuckle.
what effect on the machine when the shim height is high or low?
gansei- Putting washers under the ball stud like that will generally change the "bump steer" characteristics, that is the amount of toe in or toe out change the wheel will go through as the suspension moves through it's travel. Putting washers under that stud will give it more bump out, as the wheel travels up, the wheel has to toe out more. the closer the tie rod is to level or the same angle as the lower suspension arm, the less bump change there will usually be. The reason you might want more or less toe in change as the wheel goes up and down is, you can have less toe OUT down the straight while accelerating, then as you get off the gas, and the car lowers in front, it gets more toe OUT for better turn in. Most cars seem to have some bump OUT or toe OUT change as the suspension compresses, you can fine tune this with washers under either the inner or outer ball stud. Hope this helps!
but sorry... my english is poor.. so i could not understand exactly
when i pressed front suspension...
more washers under outer ball stud -> tire act toe-in
is it right?
1) more washers under outer ball stud -> fast corner-in
2) less washers under outer ball stud -> smooth corner-in
thanks for your reply..
is it right?
is it right?
