Team Orion Vortex Brushless motor >
Old 07-10-2008, 12:56 PM
  #601
Originally Posted by RC MARKET
12.3mm
And...4T?
higbo is offline
Old 07-10-2008, 02:16 PM
  #602
they're all fitted with a 12.3mm rotor mate...
Drift Demon is offline
Old 07-10-2008, 03:18 PM
  #603
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by higbo
And...4T?
Same
RC MARKET is offline
Old 07-20-2008, 05:59 PM
  #604
revo61's Avatar
Trader Rating: 18 (95%+)
What is the difference between race and stock 10.5? Has anyone compared them to the original 10.5 without the fan?
revo61 is offline
Old 07-20-2008, 07:06 PM
  #605
corallyman's Avatar
Trader Rating: 101 (100%+)
I read somewhere that the "race" motors were outlaw motors, and the "stock" motors where legal motors to race with, roar legal I assume. Now does this mean that the motors are the same in specs but the stock ones have the color coded rings and the engraved markings? I would like to know for sure myself. This may be wrong, but it is what I have read.
Can anybody else confirm or further explain.
corallyman is offline
Old 07-29-2008, 06:38 AM
  #606
dizzy1's Avatar
Trader Rating: 29 (100%+)
What is everyone gearing the Orion 17.5 at for FDR? 3.5? 3.6? Its rubber tire TC, getting ready for Vegas but don't have an Orion 17.5 to play with until I get to IIC. THanks.
dizzy1 is offline
Old 08-09-2008, 07:04 PM
  #607
Default Gearing
I dont have any ideas of what is the FDR?
Just need an advice, what is the recommended size of pinion and spur should i use for my car.
What I have is:
rc model: TRF 416
esc: LRP sphere.
Motor: Orion Vortex 5.5T , Orion Vortex 10.5T & LRP 3.5T
Track: Asphalt with straight line about 40-50 meters.
Can someone tell me the recommended size of pinion and spur should i use for each motor that i have. I dont need it too fast, just need a decent speed that doesn't overheat the esc and motor.
Battery: Lipo Orion 3800
Please help me...
ichigo1661 is offline
Old 08-09-2008, 07:24 PM
  #608
Regional Moderator
CarbonJoe's Avatar
Good starting info here (I know it's from Novak, but the principles are the same):
http://www.teamnovak.com/tech_info/b...r_gearing.html
CarbonJoe is offline
Old 08-11-2008, 06:42 PM
  #609
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Questions??
Hi All
Can someone please tell me the KV rate for the 17.5 & 4.5 vortex BL motors ?
How do these two motors compare to the LRP 17.5 & LRP 4.5 BL motors ?
BLUE 2 is offline
Old 08-13-2008, 08:19 PM
  #610
Thanks, give me a bit of ideas.
I just need a suggestion of pinion size and spur combination that is good for straight line asphalt track about 40-50m and at the same time keep the motor and esc at a good temperature. Any suggestion would do.
Old 08-19-2008, 04:23 AM
  #611
bigz's Avatar
Hi,
anybody know what fdr to run 13.5 stock spec in a cyclone tc? im running it at 4 for my surikarn and would like to try it out in my tc. thanks.
bigz is offline
Old 08-19-2008, 05:48 AM
  #612
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by bigz
Hi,
should be the same fdr , they are basically the same car
Marcos.J is offline
Old 08-19-2008, 05:54 AM
  #613
bigz's Avatar
the surikarn has 16t pulley while the tc has 18t. is there a difference?
bigz is offline
Old 08-19-2008, 05:58 AM
  #614
Super Moderator
Marcos.J's Avatar
just in the internal drive ratio the fdr can still be the same you will just need a different pinion and spur combination.
Marcos.J is offline
Old 08-19-2008, 09:26 AM
  #615
STLNLST's Avatar
Trader Rating: 32 (100%+)
www.gearchart.com
should be all you need to figure out your final drive ratio. 16tooth =2.4 18tooth =2.16
STLNLST is offline
