Kyosho VoneR Thread
Re: 3R lower arm binding
Originally posted by thescum
Yes Boner am using the 3R arms... There's little freeplay, although when i flip the bulk head on its head, both arms do come down, but again these are not as free as my Evo's.
RRR
Hello Boner
I will PM you my info later ok.
ok let me known asap. parts are going very quick.
0.8M gears?
Where can i get the specs on this car, the kyosho website is in jap. I guess.
towerhobbies have 0.8 modules. V1RR Evo and V1RRR uses 0.8 gears. V1RRR uses smaller pinion on first gear and uses V1RR evo's 1st gear pinion as it's 2nd gear pinion.
does the car come with CDv's?
dog bone you need to spend your hard earn $$$ for CVD
does kyosho make them though for this car?
I saw someones half built car also, and I notced the wheel hubs were plastic... +(
I have mention before, you use front CVD for Evolution and rear CVD from FW05R for 3R.
You can use alloy wheel hex hub for V1 series or FW05 series. plastic wheel hub are lighter than alloy.
Hi Boner,
Would you happen to have the dimension for the RRR's rear lower arm?
Thank you in advance.
Registered User
3Racing already making and released some Hop-ups for 3R. Those third-party companies are working fast.
3 Racing Hop-Ups for 3R
Originally posted by cvccsi
Hi Boner,
Hi Boner,
34.60mm width at other end of the arm (lower shock mount hole to other side)
51 mm length of arm
Thank you!!
v-one-rrr w/four stroke?
Anybody on have a v-one-rrr with a os-26 four stroke in it? I am interested in info regarding this kit. maybe someone from overseas can shed some light on this subject. There is some info on kyosho's japanese website but I want to know where I can get the kit in the states.
BK
BK
thanks.
