Kyosho VoneR Thread
#1081
Thanks DTM. I tried what you suggested just now, and it still did not work!! If anyone has access to the V1R rear swaybar and the V1RR swaybar could they pretty please check to see if they are identical?? This has got me beat.........
#1082
Originally posted by RC Racenews
Hi Guys
Can anyone tell me the internal ratio of the VoneR ?
TIA
Hi Guys
TIA
#1083
Originally posted by AMGRacer
OK thanks dtm!! Much appreciated.
Another question, my V1R swaybar does not work with the V1RR rear treatment. It clashes on the 2 speed gears. Is the RR rear swaybar different to the R?
[edit] I can see that the RR has different "linkages" (use threaded rod rather than a turnbuckle) on the rear swaybar, but it still seems to hit the 2 speed some.
The RR use different sway bar on the rear to the R.
YOu can now buy option sway bar only for the RR without the links. don't have the part # w/me.
#1084
Originally posted by kitracer
I am quite sure this is right.
#1085
Has anyone driven their brand new RR yet I am curiose to know how you feal about it compared to the R
#1086
Hey can anyone tell me how to post an image so it comes up directly and not as an attatchment - its driving me insane
#1087
#1088
hmm manti.. seem like alot of people is treating you like god here.
hahahah
hahahah
#1089
hahahah
hahahah
Hey Jack, where do u normally run back here in town? PA? Or MS?
#1090
MS.... pa is too far for me....
#1091
#1092
Impressions, swaybars made cornering smoother and more consistent. The overdriven front increased into corner push, but allowed me to get on the gas earlier and it pulled the car through the corner like a mild oneway effect, there was a little push as well. Definate loss of top speed due to the overdrive.
#1093
AMG: are you useing the 30mm rear foams or the 26mm?
I have a pair of 32mm Kawahara Zack projects just waiting to see what other feel about the new set up, I have ran these tyres before I like them, but I don't have the overdrive pully.
I think the body mounts will help but most of you guys seem a little sceptical give it a try I would like to know what you find.
I should be getting the RR kit sometime early Feb.
untill then the R gets all the attention
#1094
#1095
