Kyosho VoneR Thread
#9706
Re: Re: what's up K guys
Originally posted by AMGRacer
We have had a review in a recent ozzy mag where a guy upgraded from a V1RR to a FW05R and dropped .5 seconds off his best laptime.
The car looks to be as good as a NTC3 drivetrain wise with the durability of a RR.
i never knew that the car can be this good!
Ill be interesting to see how Cyrul does with it!
#9707
Originally posted by patelladragger
I'm trying to decide what nitro to make my entry back into GP. I see cryul is going to be running K in 200 mm now with FW-05R. So anyone have any input on it?
Is it worth it to consider both or just stick with a evo and a mugen clutch?
There are a couple of FW-05R's running at our track and they look pretty good, too. As AMG says, they seem to hold together better than the NTC-3.
I reckon gears are still going to be their downfall, but someone will make some hardened ones, I'm sure.
. . . but to answer your question:
EVO, Kyosho 3D Clutch, practice, practice, practice,
Just my 2 cents, you understand.
#9708
If I recall, everyone knocked .5 second off their personal bests, that day.
. . . gawd, he's gonna slap me for that one.
#9709
We had our last club meeting for the year today - Trophy Dash.
As noobatron pointed out, the track was as dusty as a Telstra share portfolio. We had a poor showing mainly because I obviously can't tune an engine, and should never have used a second hand horn on the steering servo - Doh.
Due to the conditions, everyone was chasing set-up most of the day. We ended up with 45º on the front bar, softest setting on the stock rear bar (should have bent up a lighter one), 2º more caster, 5.5mm/6.0mm ride height, 35/35 tyres, 4mm/4mm droop, Silver springs on the front, Black on the rear.
I think we could have used some lighter shock oil too, but the car was on rails in the twisty bits and my driver was pretty happy with it.
. . . now if I could just tune an engine.
#9711
Re: EVO Victory
Originally posted by tl2111
Hi All
EVO making a come back win at the dusty condition moorebank today. Setting is pretty much same as the Nat's except flat front roll bar and 42F
Cheerz
Hi All
Cheerz
. . . . . but geez, I didn't think the dust from our off road track would have travelled THAT far.
#9712
Re: Re: EVO Victory
Originally posted by Taylor-Racing
Congrats tl2111.
Congrats tl2111.
#9713
Re: Re: Re: what's up K guys
That wasn't our very own SPracer, was it?
Still I think the FW05R is a damn nice car.
#9714
i missed today's race cuz of work (won't be finishing till the 20th December ). How was the track, i was down on sat night and it wasn't too bad so i guess all went well?
#9715
Re: Re: Re: Re: what's up K guys
Yep thats him I personally take these articles with a grain of salt as well. I know Luis also struggled with the car on a larger track (Brendale) since it was undergeared.
#9716
I am getting a Kyosho V-one RR Evo... and I am just wondering, what everyone thinks the best engine is to run in this car?
Also, what good hop-up parts would be worth it to put on the car? Is there a split on the foam tires, and what would the split be?
#9717
Im planning to buy the evo conversion, is there any other parts required to fit the evo conversion in my v1rr ? can I still use the same kfactory center mount and side stiffiner (with the belt tensioner)? Im only using the standard futaba servo for steering, is it still ok with the new servo layout on the v1rr evo?
thanxs and more power!!!
#9718
But ultimatly, it's down to how you drive. The engine is half of the story
Regarding foam tires, i run 37 sore on (26mm fronts and 30mm rears). It has a 1 split in it but u can get multiple splits.
have fun!
#9719
I've just got myself the conversion kit and it's SOOO sweet, alot better than the EVO kit itself (shimo chassis, carbon fibre instead of reinforced fibreglass radio plate etc)
Unfortunantly you won't be able to use your centre mount and side stiffner on the conversion kit- side stiffener won't fit and the centre mount is different in the evo kit (doesn't have radio support mount). The kit comes with EVERYTHING you need to do the conversion so you won't have to purchase any extra bits and pieces.
The servo is mounted flat on its side as you would've seen, however it doesn't limit the type of servo you can use. There are specific brackets for Futaba, Hitec, JR etc included in the kit so you should've have any trouble mounting the steering servo. However i would suggest getting a higher torque rated servo for steering but that's just me.
#9720
As far as tire split are we talking differnt shore ratings or diameters.
