Kyosho VoneR Thread
#6121
that's it !
#6122
Originally posted by university_dave
That's not the kit fuel tank is it Manticore?
Would I be right in saying it's the K-Factory low-CG tank? If so how do you find it, I've been told that it causes the engine to run lean towards the end of a tank. Do you have any such problems with it?
I dont think that is a problem as I can tell when the fuel has almost done !!
#6123
Thanks.
I might have to order one now...
#6124
Hmmmmm.....................is that MTX-3 rear hubs on your car?
#6125
#6126
nice pipe how do you like it? and where did you get those nylon arms?
#6127
#6129
Are there extra parts I should pick up, such as fragile items, or typical wear items?
example: uprights weak, belt breakage, etc.
#6130
Can bend rear hingepins if you hit hard enough.
#6131
That's it, no A-arms, bulkheads, or hubs? I'm impressed.
#6132
#6133
Is the mugen clutch better than a rr one i dont know if ne one answer this yet or r they the same?
#6134
The RR clutch seems to be fine, apart from the fact that you need to add in the hard spring.
#6135
MRC Superbrain 959
Does the charger ur talkin about trickle the battery or uncharge it?
