Kyosho VoneR Thread
#5341
Patella,
If your still looking for another Kawahara Solid rear, it looks like Speedtech has got them in stock. How's the Negative Diff working out BTW?
#5342
RB X12 with Novarossi In Line combo...
The novarossi in-line looks good, but had anyone running this combo as yet? Or anyone running it with other motor?
I am running X12 3 port Turbo motor.
How does it perform?
#5343
Vented-brake disk
By the way for the guys posting something earlier about brake disks on the mugen and the voner:
I saw something on a Japanese guy's homepage. And i did the same thing:
I STUCK A VENTED DISK FROM THE FANTOM 1/8 SCALE, ON MY VONER. IM SURE SOME OF YOU KNOW THIS, BUT FOR THOSE WHO DON'T....
Its a little heavier on the shaft im sure. But in theory, a vented disk will perform as it is supposed to, unlike a single disk trapped between two pads.
i didnt get conned into buying those after market disks. =)
#5344
1) Is it necessary to apply tread locker to the cap screw which securing the spur gears?
2) Could this be the reason that the 2 speed shaft snapped into two? The breaking point is located at the pin hole of the brake pulley position. Or it is due to fatique/ wear and tear/ merely poor quality of this K factory shaft?
#5345
Originally posted by JordanC
No, Just give it a good nip up.
It depends on how it broke, did it split in the end of the shaft, or literally break in two? Were you undoing/doing up at the time, or driving?
As i was setting up the motor off ground, when i noticed the spur gears were having some weird noise of something loose...like the cap screw went loosen the last time...
#5347
Yeah but you hit too much too often.
#5348
Originally posted by DCR1TWO
Patella,
Patella,
#5349
Re: Front and Rear Universal Driveshafts for V-One RR
Originally posted by racer rich
Hello. I have a question regarding aftermarket universals for the Kyosho V-One RR. A few months ago I was going to purchase a V-One RR, but I decided to see what the new Mugen and Serpent would look like. After seeing their new releases, and not being quite too pleased by their "updates" at all, I have now decided to purchase a V-One RR.
I would like to get aftermarket universals for my soon-to-be V-One RR. I noticed there are 3 manufacturers/types of universals for the V-One RR. Below is the manufacturer of each universal along with a picture of it:
Here is a picture of the Five Stars universals for the V-One RR:
Here is a picture of the "polished" Integy/Eagle universals for the V-One RR:
Here is a picture of the "black" Integy/Eagle universals for the V-One RR:
I would like to have some feedback on these universals. I am looking for universals that are lightweight yet durable. The K-Factory universals on my Reflex are very fragile and bend very easily. I would like to have some more durable units. I believe patelladragger once stated (I am not perfectly sure so don't take this to heart) that the "polished" Integy/Eagle universals are fragile and break easily. Can I have some personal experiences with these universals that are listed and pictured above? Also, I noticed the "black" Integy/Eagle universals sell for $10.00 more than the "polished" Integy/Eagle universals(both are sold at Integy's online shop). I wonder why the difference in price? Which universals on the market for the V-One RR are most durable and provide the best performance?
Thanks in advance!
Thanks in advance!
I've tried most of the universals including the kyosho ones and those black integy ones are the best quality. They are built like the V1RR rear dogbones with the reinforcement in the center. Don't waste your time with the 19.99 polished integy ones as they're worse than the reflex kfactory uni's in terms of durability.
I have not had the kyosho ones break but some clown sold me a used RR with one kyosho uni snapped and the other warped but I've never been able to do any damage to those black integy uni's. Not that It would be impossible - but it would take something serious to hurt them.
#5350
Foam tire setup
Hey guys, need your help on a couple of things.
I'm going to run on treated asphalt for the first time in a couple of weeks. Any recommendation for tires? I have the V-1RR. For the front; I have a front one-way, an active diff and a standard diff. I'm running a negative diff in the rear, by far the coolest hop-up I ever put on a car.
I'm a concrete guy, so any basic setup info will be helpful.
Oh, one more thing. Steering servos. To your own experience, what is the most reliable servo out there. I had a hitec digital servo and it tanked. Standard servos aren't strong enough. Airtronics is the brand here in Dallas.
Thanks, in advance, for you help.
#5351
auto where are you going to be running?
#5352
Finishline in Hurst.
#5354
Originally posted by Taylor-Racing
Not sure what you mean by "locked up".
But, yes I find it strange that Kyosho would put up with, what appears to me, to be a much smaller market share than they could actually attain. And I would expect the US to be a much more significant market than Australia - probably more than ten times bigger.
#5355
yes
So did the shaft break in half, or just slip at the end?
