Kyosho VoneR Thread
#481
OK I have found the first weakness with this car!!! Well every car is allowed one right
The front up stops are made of a quite flexible plastic which flexes a heck of a lot when the hex screws bottom out. Therefore trying to set the chassis from not hitting the ground is quite difficult. I am going to get the K Factory aluminium pieces which I hope will fix this........
The rear ones work very well BTW.........
#482
#483
I understand that the upstops are useful for stopping the chassis from slapping the ground. At our track the places where you brake heavily are also very rough meaning the front of the chassis seems to hit the ground some giving understeer. I could raise the ride height, but that would affect the handling of the car elsewhere......
Or am I going the wrong way here........
#484
#485
Originally posted by Manticore
well, in that case your car stop faster without the up stop. your main chassis does the job for you .
#486
LOL thats true!!! I wouldn't mind except for the understeer.......
#487
No I am running foam trued down to 60mm........
#488
#489
Hmmm interesting..... I am running 4mm ride height....... Even if the track is rough you think it probably is not striking??
#490
#491
The track surface is not broken. The surface is wavy in some areas mayby 1/2 inch variations......
So you would not recommend using upstops..... Can you see a bad side to using them.......
#492
I dont know how you can handle that even you have up stop !!
#493
well, 1/2 inch is over 10mm !!! that is big difference.
#494
#495
Originally posted by Sydewynder
My track has a dip in it that will cause your car's wheels to leave the ground. I'd say the dip was much more than 1/2" (12.7mm).
