Kyosho VoneR Thread
#302
Can someone post up their V-One R setup that used foam tires, sway bars, and frot one way with sold rear? thanks!
#303
Finished building up my 2nd V-One R Finally! Now it's time to put it on the track. Can't wait to try out the new RB X-12 5 port turbo engine! Here's a pic of my 2 V-One R's now!
#304
Well my foam set-up is without a solid rear axle, 10,000 wt. rear diff. Maybe a starting piont. Hard front tires Jaco red, purple Jaco rear. Gold springs, 50 wt. front and rear. Rebound stop front 0 mm, rear 5mm. Shock mounting front N, rear IN. Ride hieght 4mm front 4.5 rear. 2 degree rear camber, 2.5 degree rear camber. Front toe 0, rear 2. Castor 10 degrees.
#305
Hey adulmundo, that set-up is also with front and rear black sway bars. The track I have this set-up for is for a extremly high traction big track. If I were to run Dbl. purple front tires, the car will traction roll very easy. That is why the Jaco Red fronts. Hope this helps.
#306
Guys, who has had problems with the dogbones popping out of the cups when u clip a board or another car?. It has happened a few times already. Toss them for uni's i guess?
#307
#308
#309
Originally posted by Mauler
Think someone asked that way before... try the MTX dog bone... slightly longer... put it on and forget about the O rings... Save the money on the CVD for some other hop ups...
Unfortunatley I am a buying freak, and I couldn't resist buying the CVD's when they came out since they looked soooooo cool (like that kid in a candystore feeling ewwwww ahhhh!)
#311
#312
Originally posted by Manticore
try to narrow the front a bit and that will solve the problem without spending a cent on it.
#313
Upon narrowing, you could try the 2mm offset wheels...
#314
I think only tamiya has 2mm offwet wheels.
I am waiting for the rear body support for Lola body, front "hand shake" sway bar and the wide bumper. Anybody knows when they will be available?
#315
Is there a set width guys or just enough shorter to solve to problem. A friend of mine is running 198mm on front and he doesn't seem to have the problem........ any sugestions for width?
