Mugen MBX5R
#542
best way to do that is look at one in person (local track) and see if they will let you drive it and watch what they do to prep one!that is what i did. you make a choice like that then it is no longer an opinion but one based on experience
#544
lol is not punctuation.
#545
after each week end i clean them off. i run the lota set up that are plastic and so far there are no scuffs in them only part that makes them not look new is the discoloration from the teflon lub spray i use on them. i have 2 gallons or so on the stockers and 4-5 on these
#546
#551
some people run it close to hughes set up with anti bump steer washers and moving the rear camber link up 1 spot on the rear tower
#553
rcmike
unfortunately Innovative doesn't have a website at this time. Some of the bigger online retailers like Carolinasrc, Bmainhobbies and Amainhobbies carry there stuff thou. Not sure how soon the new pivot balls I'm testing will be available to the public but I will get an answer and post back here soon.
Innovative has some cool items they sell like a Stainless steel heavy flywheel for the GT2, some trick tools and his lottaballs for pivotball cars, velocity stack carb inserts for Novarossi carbs etc etc.
Search some of those sites and you'll see there stuff.
#554
for removing the locknuts on the pins i simply cover over one end of a closed wrench with some glazing tape, this stuff remains sticky for ages and is totally flexible so you can push the nut in till its held and then just screw it on, presto easy changes if anyone can tell me an easier way ill try it.
#555
Quick question, Ihave just finish building my new mbxr buggy and was just wondering if people left the small orings on the cross pins out of the front and centre diff aswell? The instruction say to only leave it out of the rear and that is what i did.
