Mugen MTX-2
#1411
Tuned Pipes
What tuned pipes are you guys using? what color shocks on what ground?
~Brandon
~Brandon
#1412
Re: Tuned Pipes
~Brandon
~Brandon
What do you mean by What color shocks on what ground??
#1413
Re: Tuned Pipes
~Brandon
~Brandon
I use the 50221 Novarossi pipe Had to cutt my header though to make it fit
#1414
Oh also the Team Associated RC10 Gt pipe Ugly pipe but the low end is awsome!! especially on tight tracks & the pipe is a tank will never bend!!
#1415
Light blue shocks on Asphalt (Both rear & front)
#1416
Speaking of dampers, is it possible to get the front or rear damper as a unit? If yes where, if not then where can a get a damper casing?
#1417
Re: Tuned Pipes
~Brandon
~Brandon
I use both a associates pipe and the standard rex pipe.. I have a inlinerb x12 in my sights now.
To ah10:
Where did you get your 50225 pipe from. I wanted to go with that but couldn't find it anywhere.
#1418
Pro Spec kit owners ????
when you were building your kit. did you have everything except the 4 screws for the front diff and the gears( if you wanted to use the gear diff in the front instead of the front 1 way) ???? i am just woundering if that is how it is packaged or i am just missing these items ? i just wanting to know befor i contact mugen to see if they will send me the screws and the gears for the front diff.
thanks ,chris
thanks ,chris
#1419
Re: Re: Tuned Pipes
#1420
Thats ineteresting. my local hobby store didnt make me aware of that I run the Nova Mega .12 MS
I got a good deal on this new pipe im gonna try. It looks like the RB .15 inline but its by Team Magic I have a post up in another thread w a photo of it. Cars w/o bodies thread
#1421
My understanding is that "turbo" pipes have a larger internal diameter on the stinger than is allowable under ERFA, ROAR, etc rules. They allow higher exhaust flow and therefore get more power, but are also noiser. I run turbo pipes on turbo plug and non-turbo plug engines, so I know they do no harm to the engine and performance is excellent.
#1422
#1423
Excellent! yeah I run a .15 turbo pipe now. I like teh feel. Someone was telling though becareful of the back pressure. That due to the bigger stinger it may not be creating enough. Not sure how true that is.
#1424
RB X15 Turbo pipe! Yeah! mucho grunt from that pipe
#1425
