Mugen MTX-2
#1081
Originally posted by SHARP
Really mean what? Mean to be rude to me! Was my post wrong?
In fact I like the Kawahara 2 speed very much, when it shift it doesnt have to jerk to the car very smooth in deed! really depends on how the track is set up! the track that I run my car has some short straight and a nice highspeed sweeper so some times it would shift right in the middle of the sweeper and short straight so when it shifts it is much smoother and doesnt jerk and make the rear end stable compare with the finger type 2 speed! other than that the finger type 2nd speed works just as good!
#1082
Originally posted by AMGRacer
Grrrr thats the problem, the Oz dealer will not bring part T0701 in for me!?! If anyone can get hold of one for me and will mail it to me I will pay well!!!!
The TO701 is for the Novarossi CX12
So it depends on Which motor you want to put it on as the shafts are slightly different.
The O.S. has 5mm thread on the end of the crank shaft,
while Novarossi motors have a 5mm stud screwed into an internal thread on the end of the crank shaft.
It looks like the O.S. nut would fit on both but the flywheel would be out 5 to 10mm further on the Novarossi so you would have to sort out the alignment of the motor.
So let me know and I may be able to help you.
#1083
Originally posted by muugen
I have the O.S. engine nut TO704 - which fits on O.S. CVR
#1084
I basically want to attach a Mugen centax clutch to a novarossi standard shaft engine. Of the T0704 would work that would be great, got some pics??
I found the part that you want! Mugen T0701, I have seen it myself too! I really think it would fit onto Novarossi engine the convert a standard shaft to SG!
Seems to me you will have to take the crank shaft out then remove the the short threaded shaft(like an inch long) then replace it with the new shaft!
PM me if you still need this part! have you ever thought of getting a new SG crank? I have seen one yesterday, for Mugen MT12 and it cost $3X?
#1085
Ah10...did you get a new crankshaft for your MT??
#1086
#1087
Originally posted by Ah10
Calling AMGRacer Calling AMGRacer Calling AMGRacer Calling AMGRacer Calling AMGRacer
#1088
Thanks Ah10!! The "old man" has already worked his magic (in HK) and has sourced one for me. I am positive it will work because I took the shaft out of my RS12 before I put it into the car. So I will loctite this thing in place with some red and hopefully will have a SG crank for less than $3x I will take some pics when I do this so everyone can see what I am talking about!!!
#1089
You are right, Manticore was asking me how I like the 2speed!
Does Kawahara have their own website, or any website with pics and info on their products? Thanks again.
#1090
Thanks Ah10, I thought I had upset Manticore! Maybe I have.
#1091
Are all of you still using the one hole piston on the front piston? I've extra two holes piston and put them on the front and use same WT shock oil all round. I find this is more accurate and easy to work on the suspension so far.
#1092
What's this achieve Moon?
#1094
Body types + Mounting
Can anybody tell me which holes on the posts they use for mounting their body shells?!
The reason I ask is because I have Lola style body (which uses the lowest holes) but I don't want to cut the posts that low because I am probably going to get sedan body, probably Accord or Stratus.
So if you could tell me how many holes up the post you are using for the lower clip and for which body this is it would be good.
Also do all the nitro tourers have the body posts in the same place? What I mean is could a sedan body which has had post holes drilled for MTX-2 fit on a Kyosho or NTC3 using the same holes?
Thanks in advance, I know it must be hard to make sense of my questions!
#1095
Originally posted by Motorman
I run 2 hole up front and double the shock oil weight. 80 or 100 in front.
less packing and more consistant during a long race.
