Mugen MTX-2
#1681
Will the lola body work with the stock front tower?
#1682
I used to chop down the stock shock tower and make the body shell sits lower
#1683
#1684
Originally posted by Manticore
yes, but you need to make the body shell taller !
#1685
Thanks Manticore & dtm. I have a lola on order. I still use the plastic shock towers so it will be less painful
#1686
Ears
LOL, they are on there so I can mount my rear view mirrors on them.
#1687
Does anyone have a good diff setup for the MTX-2. The rear end is all over the place. I mostly run foams, but sometimes I race at tracks where foams are not allowed. Here is what I'm currently running:
Front:
Light Blue Spring
80 wt shock oil
2nd hole from the bottom (Shock Tower)
Diff - 30,000
Sway-bar - Softest setting
Rear:
Silver Spring
40 Wt shock oil
2nd hole from bottom (Shock Tower)
Diff - 5,000
Sway-bar (None)
I run on tight tracks that have high bite and on 1/8 scale size tracks with high bite (Crystal Park)
Front:
Light Blue Spring
80 wt shock oil
Diff - 30,000
Rear:
Silver Spring
40 Wt shock oil
Diff - 5,000
Sway-bar (None)
#1688
rcfiend
What tires? That's a pretty important part of your setup too. Try standing up your front shocks all the way and laying your rear shocks down all the way. That should give you push. If not, go with some harder tires up front and/or softer tires in back.
Then you can start laying the front shocks down one position at a time and standing the rear shocks up one position at a time until you get the balance you're looking for.
#1689
Front:
Light Blue Spring
80 wt shock oil
Diff - 30,000
Rear:
Silver Spring
40 Wt shock oil
Diff - 5,000
Sway-bar (None)
Front:
Light Blue Spring
80 wt shock oil
Diff - 30,000
Rear:
Silver Spring
40 Wt shock oil
Diff - 5,000
Sway-bar (None)
#1690
I'm currently using 45 shores 26mm in the front and 42 shores 30mm in the rear. I've heard conflicting views on the shock position, I was told that if you stood the shcocks up then they would provide more traction, but you're telling me to lay them down????
#1692
What toe and camber are you running in the rear? Try 2.5 toe in and 2 to 2.5 camber (each side).
Is the back sliding on throttle and/or off throttle?
Run as little droop as you can if the track is smooth. Is the track sprayed?
Contrary to popular belief from my experience with this car, the silver spring is too soft. I'm using blue all around.
#1693
#1694
It is the other way around! Lay the shock all the way down will give you more traction but more body roll. Stand it up will give you less body roll but less grip as well!
#1695
Thanks, AH10, I'll give it a shot. This car is so difficult to setup compared to some of the other cars I've had. It either understeers or oversteers.
