Core RC 5000mah Lipos...
#560
Absolutely it will.
Just set it to Pb (Lead Acid) and turn it loose!
#561
Can somebody please verify what modifications are needed (if any) to make the Core 5000 lipo fit in a Hot Bodies Cyclone. I'm referring to the standard Cyclone, not the S version. Thanks.
#563
#565
Can the UDC-20 balance an Orion lipo? If so, what plug would you use?
#566
R/C Tech Elite Member
It can, and I would look at www.allerc.com for an adapter from the"JST-EH" thats on the charger to whatever balance plug is on the Orion
#567
the orions run a stupid 3 banna plug set up (3200carbon) u have your main positive and negatice which are your normal size bullet or corrally plugs then a little 2mm plug for balanceing, voltage from either the positive or negative to the 2mm plug is 3.7v so is between the to cells, will this plug into the charger?
http://www.allerc.com/product_info.p...oducts_id=2568
it doesnt matter what fitting is on the other end as ill have to cut and resolder bullet plugs ,
cheers
cheers
#568
I called allerc this morning and the guy said he doesn't carry any kind of adapter for it, since they don't sell Orion batts. Guess we'll have to fabricate something...
#569
#570
ok well here is a basic one orion says to use now we just need Adam to help us adapt it to the udc 20 please Adam
http://www.team-orion.ch/orion/faq/harness.gif
sorry
sorry
