ALTOONA RACEWAY FORUM
#211
Doug, I will say that it was a fun race to be in. I wish it would of went on for another 20 to 30 minutes! I should have saved my tires for the main but we all learn from miscalculations. My tires were bald at a couple spots after that race. Track is great, traction is real good and hope to be back when time allows. The start of the race was tough for me. That was the first time I left the pit lane like that and I over shot the first turn and thought I was going off the track over the double. When I made my pit(thanks Sam), I thought I would have a good lead but as soon as I left I recked over the double and that blew that idea.
Great Fun!
C.R.
Great Fun!
C.R.
#212
cool CR, I'm glad you liked the track! You're right, I could have done that for another 20 or 30 minutes, or at least until my arm started cramping!!
toon town 1/8th scale/1/8th sport racers - quick survey:
question #1, when was the last time you changed your shock and/or diff oil?
question #2, when was the last time you looked at your clutch/clutch bell bearings?
question #3, how many setup changes have you tried to improve consistency?
question #4, when was the last time you built a new set of tires
P.s. tires, diff oil and shock oil are all available at TRS ( im sitting here all alone right now!)
or - the answer that best applies to you is i take my car out of the bag in the same/similar condition it came off the track last week, push a glow starter into the engine and hope for the best. (travis chamberlain, no need to respond, I've already got your answer logged!) how was Candada eh?
ED - I MUST BREAK YOU!!!! MY ZIP ZAP will BE READY FOR THE COLD WAR THIS SUNDAY!!!!!!!!!!!!!!! bring on the tothenator!
#213
I went over Shawn's Revo completely for this upcoming weekend's race. I would like to know if anyone has a Hudy setup board http://www.hudy.net/flash_stuff/all_in/index.htm and if they think it was worth the money.
See you all Sunday!
See you all Sunday!
#214
Survey response:
1. Shock oil-changed at the track-tried to change handling
Diff oil-After the last time I raced-wanted to have more on power steering
2. After this past weekend-I took the clutch out of the car and balls fell out of the clutch bell!
3. Some-droop, ride height, pistons, oil, diff oil, a little drag on the rear brakes, rear wing, sway bars, rear roll center, toe, camber, that's about it
4. The last time I raced-Switch 2.0 clay
C.R.
C.R.
#215
Set-up board
This is only my opinion!
Waste of money for off-road
Run your vehicle for 7 minutes after using the set-up board then recheck the settings and I bet 95% of the settings are different.
If you raced on an indoor track that was smooth and high bite then maybe but not outdoors with big jumps and rough tracks.
I use a ride height guage(Associated), camber guage(RPM), and toe guage(RPM).
Use the money you saved from the set-up board and buy a couple sets of tires.
C.R.
C.R.
#216
Douglas.......... all of the above have been done at least once so far except for the damn tire thing.......I think you all now how I feel about CA'ing tires.
And one more thought..........we might have to hire the A-TEAM for this Sundays post-race activities at the Ceaser!!!
#217
See you all Sunday!
See you all Sunday!
#218
#219
Joey Petyak - 1/8 Scale
I saw an earlier post about this....
We have a Sportwerks Turmoil RTR with Spektrum Radio for $400 for someone who is going to race.
Please spread the word.
#220
Pre Mounts
gix....these have your name all over them http://www.amainhobbies.com/product_...ducts_id/13194
As with most other stuff, TRS has them in stock at the same or better price.
Please just ask, you might be surprised at what we will do for people who want to race!
#221
Forza 2
Getting pumped for tomorrow nights showdown!
Gotta get a webpage up!
#224
Jeremy,
Carpet and offroad are two different types of racing.
Carpet-cars are 'tight' with controled track surface.
Off-road-cars are designed to have 'slop' at the pivot points to make them easier to drive.
Take an off road vehicle with the tires on(that is how it is raced) and drop it to check camber and you will get different reading almost every time.
Even if you put a piece of paper under the tire that you are checking so it doesn't grab the surface, it would still read different. That's a fact!
I think getting the balance of the car is way more important than a 1/4 degree of camber!
Check the balance of the 8ight and it is not as close as one may think.
C.R.
C.R.
#225
i have both the touring car ultimate setup station and the 1/8 one, i swear by them both! hudy also makes the toe guage for truggys as a seperate part. i went and bought a tempered glass cutting board to use as a setup board and its about half the price of the hudy one......make sure if you get one to get something level to check the car on becuase these things are sensitive. not sure who this is (cant get used to the screen names here), but i always have mine with me if you wanna check it out before getting one.
Shawn at Altoona http://www.altoonaraceway.com/images/042107_017.jpg
I would like to see the setup board if you have it along this Sunday and thanks for offering.
