Serpent to 1/10th EP Touring Kit S400
#1201
#1202
Start with a 28 tooth pinion and go up from there!! This may be a little low but I don't know how tight your track is where you race. Are you using the stock spur gear? Also tire weight and inserts also play a factor but 28 should be right around the ball park!! You should be able to find whats best for your track from there!!
#1203
I am now running a LRP brushless 13.5.The track I would say is a medium open track as far as track sizes go and I will be running rp 30s.The spur gear is a 95t.What pinion should I use to start out with?
Also how are you guys freeing up the drivetrain??
My car feels pretty tight.The belts arent too tight though.
Thanx in advance.
Mike Malinconico.
Thanx in advance.
Mike Malinconico.
#1204
So therefor Serpent is working on long outdrives to use the diff as a front diff.
#1205
Thanx in advance.
Mike Malinconico.
Thanx in advance.
Mike Malinconico.
Hope all of this helps!!
#1206
Super Moderator
Thanx in advance.
Mike Malinconico.
Thanx in advance.
Mike Malinconico.
with the sintered rotor i would star with a 50t pinion for a 4.14fdr if you have the bonded rotor start with a 45t and go from there keep the temps around 160 to 170 or with the sintered rotor 150 to 160 with the bonded rotor. The belts sould loosen up after about 8 to 10 runs or so if not soak them over night on wd 40 as stated above
#1207
not a problem with tamiya 48mm shafts
#1208
Thanx alot for the info.
#1209
The advice Marcos left is right on....
Thanx in advance.
Mike Malinconico.
Thanx in advance.
Mike Malinconico.
#1210
#1211
yep it works fine
I ran it twice last week , first time on primafelt carpet and on a rubber type sports floor and it was faster than using a spool and easier to drive , tq'd and won both meetings by a clear lap on second place man
just experimenting with different oils and greases for the optimum set up
#1212
Nice,
Does this require lots of shimming?
I guess without ever seeing the car plusminus 2mm?
#1213
about 2mm on cell side and 0.5mm on motor side seems to get the belt to run right
#1214
Thats good, could i take a 10x15x4mm bearing on the cell side then?
I gain 1mm from that then.
Or am i mistaken that the S400 uses 10x15x3mm bearings at the diffs?
#1215
that was my initial idea but when I measured the serpent bearing it was
10 x 15 x 4 yet all parts list show 10 x 15 x 3 ?
so I just used shims
