Serpent to 1/10th EP Touring Kit S400
#2822
S400 Superstock on Asphalt
Hi
My car works great on asphalt using foam tyres. Im running the rubber spec car. Normally 35 shore all round. Mazda 6 body.
Things to look out for:
Because I am using foam tyres on a rubber spec car, the rims touch under heavy load on the bottom ball joint of the shock. You can either just grind the rims a little bit, but what I did, was just move the bottom shock mounting position to the inside hole. The obviously changes the shock angle, so to compensate, I went 1 hole down on the top as well. Its not exactly the same as std, but close enough, just the whole shock is now more inboard.
I layed my shock down 1 more position on the rear, as well as 1 down on the front. Otherwise still on the std setup. The car is excellent out the box.
Shock positions - bascially go all the way down and then up 2, all round.
Loosen the belt tension 1 on the front and rear belts.
On my mod car, I do the same on the shocks. Leave the belt tension std.
Lengthen the front camber link, to the inside hole (closest to the middle of the car.
Both cars the rear diff is very tight.
Make sure you put some locktite on the grubscrews that hold the centre pulleys and spur gear, and I put a bit of pliobond on the servo saver nut, and tighten in another 1/2 to 1 turn more than the manual.
Hope this helps, otherwise pm me, and ill see if I can help.
Cheers
Cheers
#2823
maybe between us racers we can help each other out, i have tbh a few spare as most of the stuff i got recently went straight on the car but if anyone needs stuff post here and maybe someone will have it laying around in the pitbox somewhere, also pm shops you know have some serpent stock i know its better to support LHS but when in times of need etc
for example i needed a front lower bumper and although i havent got a S400 one i know one of the other serpent ones fit but needs trimming down so for now problem solved, theres always a way
#2825
I have a ton of spares for the S400 after my last Serpent experience back in the "old days" and I also need a few parts that I am missing for a rebuild - maybe we should all list out what we have extras of and what we need to replace and figure out a way to help each other out and get our cars back onto the track - and winning.
I will list my NIB/NIP spares tonight when I get home and see who can help me out with some parts I need.
Cheers,
Yak
Cheers,
Yak
#2826
#2827
Bumper
Hey slowcoach
I think the bumper you are talking about is #803166/#802209.
The correct one is #803163, but ask your local hobby shop if they have any stock of 802205. Its exactly the same as #803163, but was originally under the serpent 710 part number and is now under the 720 part number.
Cheers
Cheers
#2828
Hello, I’m new in the 1/10 electric rc cars. I have my s400 with a 13.5 BL LRP motor and a 30c 4200mah battery. Two questions,
- What is the gear ratio of the s400?
- What spur/ pinion combo is the more recommended for that motor.
Thanks in advance for the replies…
#2831
Meanwhile you cant even buy the stock driveshafts. Why do they "release" hop ups that no one will ever be able to buy.
I knew when they opened serpent america that they wernt gonna keep that stuff stocked
Great car though, just wish I could buy parts. Im one bent bearing holder away from having to buy a TC5r
#2832
Great car though, just wish I could buy parts. Im one bent bearing holder away from having to buy a TC5r.
#2833
