Serpent to 1/10th EP Touring Kit S400 >
Old 03-19-2009, 03:16 PM
  #2806
Default Online Setup Sheets
I have found a site where you can store setup sheets of your Serpent S400:
rc-setups.com
Before posting you have to sign-up.
efka is offline
Old 03-19-2009, 07:16 PM
  #2807
spurgear's Avatar
got my chassis protectors today. thanks rommel!
spurgear is offline
Old 03-19-2009, 09:02 PM
  #2808
Rommel's Avatar
Any questions/thoughts or opinions please let me know
Rommel is offline
Old 03-23-2009, 11:00 PM
  #2809
fly_wheel's Avatar
any1 like to post up pics of their S400 here?
would really like to see what kind of mod has been done to s400 after a year plus of production.
fly_wheel is offline
Old 03-29-2009, 08:33 AM
  #2810
slow coach's Avatar
can someone help me out with a question, i got hold of a S400 second hand a little while back and have just stripped and gone through it again and rebuilt as per the manual, i noticed when i was assembling the front end the previous owner had changed the blocks to 2x 0.0 toe blocks instead of the kit 1.0/3.0 toe blocks, could someone tell me if this is a popular tweak and what it does to the car,
cheers Jason
slow coach is offline
Old 03-29-2009, 06:12 PM
  #2811
M-Technic's Avatar
Trader Rating: 15 (100%+)
It narrows the front end and (theoretically) allows the front to rotate easier.
M-Technic is offline
Old 03-29-2009, 06:37 PM
  #2812
yyhayyim's Avatar
Trader Rating: 26 (100%+)
cheers Jason
Jason, like M-technic posted, by using the 0 and 2 blocks, instead of 1 and 3 blocks, it allows you to keep the same inboard toe out, but reduces the over all front track width making the front end narrower than the stock 1 and 3 suspension blocks. With a narrower front end, you get increased frond end traction/bite, since the car will roll more and transfer more weight to the front end when cornering, resulting in more over all traction/steering at that end. This is typically usefull when you need more agressive turn in or over all steering, especially on smaller or tighter tracks, med grip.
yyhayyim is offline
Old 03-29-2009, 07:43 PM
  #2813
brqsdad's Avatar
Has anyone had any luck running the s400 in stock foam? Any info wpould be greatly appreciated.
brqsdad is offline
Old 03-30-2009, 01:45 AM
  #2814
ds400's Avatar
Default Super stock setup
Can some one post a good superstock asphalt setup plz?
ds400 is offline
Old 03-30-2009, 02:08 AM
  #2815
slow coach's Avatar
thanks for the replies im just in the process of rebuilding the car with the CFI short arms will these make the front to narrow or will i be ok, also just to clarify i have 2 of the 0.0 blocks so there is no inboard toe on the front arms, im struggling to find any info as to what the front inboard toe changes driving wise
Old 03-30-2009, 09:49 AM
  #2816
wstuart's Avatar
Trader Rating: 117 (98%+)
does anyone know how often serpent america restocks parts for the s400
im looking for some bearing holders - the metal parts that the shock tower attaches to
wstuart is offline
Old 03-30-2009, 09:54 AM
  #2817
spurgear's Avatar
Anyone can recommend what pinion i should start with for a 102T 64P spur in my S400? Im using a Mamba 7700Kv powered by 7.2v lipo.
spurgear is offline
Old 03-30-2009, 10:15 AM
  #2818
slow coach's Avatar
you can use the other end mounts and they will work, i cant remember which ones but one end is stronger and a few UK drivers use them both ends to reduce breakages
Old 03-30-2009, 02:36 PM
  #2819
M-Technic's Avatar
Aren't we all.
Old 03-30-2009, 09:10 PM
  #2820
wstuart's Avatar
Hmmm i see
You know ive been wondering if this chassis is what has actually made me faster, or if its just my fear of crashing.
Every time I race it im thinking "ok you dont have parts for it so just avoid wrecking". Next thing Im bumping form the B and making 2nd or winning the A. Slow is fast, or I guess in this case scared is fast
wstuart is offline
