Serpent to 1/10th EP Touring Kit S400
#2131
I think I can post here if I want to. Got the answers I was lookin fore and they were not as cold as you sir
#2132
TeamButter, thanks for the offer to look at my setup sheet. I can't really complain as I am now consistently in the A final at my club since getting the S400 but think there is so much more to the car.
A look at our track may help as well;
http://rcracingni.co.uk/wordpress/?page_id=383
And the notes in case they don't come out in the JPG;
1mm spacer under rear hinge pin blocks, 0.6mm under front.
A Final, 5th and 3rd. UK top deck. Narrow hexes on front
#2133
There are a couple of track pictures towards the end of the gallery...
#2134
R/C Tech Elite Member
Waz up Randy,
Talking about your Reedy set up:
Why the stiffer dampening (55Wt oil?!?!?) Maybe you mean 55CST oil from Serpent, or really a 55wt oil?
It seems like with the thicker oil the car wont roll as much and maybe be more reactive, but have less turn in...that's where your previously mentioned 3 set up changes to get more turn in come into play?
#2136
I will take one and post it...
#2137
Here you go...
I do like it as it seems to generate more grip than the kit top deck. If you look closely you can also see were you can add stiffeners - I have added a front one using parts from the XRay T2 kit.
I should mention, for those that were not aware of the UK top deck - It is not the top deck that comes with the kit. It came out of Serpent UK - the distributor for Serpent in the UK and was designed and created by John Russell and the UK Serpent team.
#2138
Randy, any chance I could ask you to have a look at my setup sheet with a view to getting a bit more cornering speed - I suppose it feels like it is lacking a bit of mid corner steering.
#2139
Here you go...
#2140
Mid corner steering is probably the hardest to find, but I have a couple ideas.
First off, by using the UK upper deck you would need to alter your setup to get it to work. It looks like it would flex a lot, compared to the stock one which flexes very little. If your chassis flexes too much, you will scrub speed in the corners. I would try back to back runs with the UK deck and the standard top deck, as I honestly think you will get some of your cornerspeed back by stiffening up the chassis.
Other things to try would be a longer front camber link, I could see your current link getting into the corner very well, but dumping over too much throughout the turn.
Try your swaybars in the outside holes on the arms.
Try .5mm anti-squat in your rear end, this will definately help the car rotate, for some, it is too much though.
One simple thing to play with would be camber adjustments, start off by using less rear camber before you use more front camber.
Give those changes a shot, I've got plenty more for you if they don't work.
#2141
Randy, thanks for the ideas, much appreciated.
We race every two weeks (and our race was yesterday) so I will have to wait for two weeks to try these out!
#2143
Randy, me again... when you say "Try .5mm anti-squat in your rear end, this will definitely help the car rotate, for some, it is too much though." does this mean adding a .5mm shim under the front of the rear hinge pin mounts. In my case I am already running 1mm shims under both mounts at the rear to raise the roll center a bit - should I be looking at adding .5mm or removing .5mm from the rear?
I originally raised the from .6mm and the rear 1mm to get more grip.
