20 Minute Electric Main Li-Po Truck Class
#391
It sounds like people will be picking up a 12kmah & a 19 turn for the r/c pro series nationals.
#392
why you say that partywagon. I went 30 min on 8000 running a 7.5 I thinking of going 10.5
#393
[QUOTE=Craps;4392915]
Hour long mains sound like a good way to dump in the middle of a race w/ an 8kmah lipo if you aren't going to swap packs.
#394
Again good luck!
PS. I don't care if you guys race Castle. Just giving you guys a hard time.
#395
Turn the timing way down on the mamba & set that punch control at around 50%. This will greatly increase your run times. When your turn the timing down it will make a motor like a 5700 perform more like a 13x3 instead of a 10x1.
#396
Too many racers want to over motor a 2wd stadium truck that also is very inefficient. Most tracks even a 7.5 is too much and that includes the big 1/8th scale tracks that usually have just one long straight that is not where the races are won!
#398
Couldn't agree more Craps, I started with a 5700 MM and now running a 4600. I would run a lower KV Motor, if i could find one without being a fegaio. I'd like a 2800 lehner basic XL, should be able to handle some serious gearing and maintain efficiency
#399
Hacker motors have been roar aproved. Do I need to say more? I believe it is their e-40 series in any wind for mod. You can go & check the tc section to find out.
#400
where are you going to run a hour at. That would be fun to do.
#401
Craps had mentioned earlier that the nats would be 45 minutes or an hour.
#402
sounds fun to me
#404
From ROAR's website:
Here is the link to the page I copied it from: http://www.roarracing.com/approvals/brushlessmotors.php
Roar Approved Brushless Motor List
Brushless Motor Approval List
Type Importer MFG Description Approval Date
Modified Novak Novak 1050 Teardown, bare A1 can ends, purple band 3/28/2005
Modified Associated/Reedy LRP Brushless N.E.O. 1 gray can, black end caps, VTEC 9/19/2005
Modified Novak Novak Velociti bare A1 can ends, purple bands 9/19/2005
Modified Associated/Reedy LRP Vector X11 Brushless w/bonded or sintered rotor 7/1/2007
Modified Orion Orion Vortex Brushless w/sintered motor 7/1/2007
Modified Novak Novak 3410SS 10.5 Pro 2/5/2008
Modified Hacker Brushless USA Hacker E-40 (any wind) 2/25/2008
Modified Schumacher USA Speed Passion Speed Passion Comp Series 13835 (any wind) 2/25/2008
Modified Trinity Trinity TRI102xx 2/27/2008
Stock Novak Novak 3417SS 17.5 Pro *2/15/2008*
Stock LRP LRP Vector X11 Stockspec 17.5T *2/27/2008*
Stock Hacker Brushless USA Hacker E-40 17.5T *2/27/2008*
Stock Losi Losi Xcelorin 17.5 LOSAB9406 *2/29/2008*
Super Stock Novak Novak 3413SS 13.5 Pro *2/15/2008*
Super Stock LRP LRP Vector X11 Stockspec 13.5T *2/27/2008*
Super Stock Hacker Brushless USA Hacker E-40 13.5T *2/28/2008*
Super Stock Losi Losi Xcelorin 13.5 LOSAB9405 *2/29/2008*
* Conditional approval until 5/31/08. See ROAR website news section for more details.
#405
Here is a dist. in the u.s. for the hacker motors.
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
It's pretty funny that they managed to undercut feigo in this market.
