Losi XXX-NT AD2 Diff Problem
My diff is totally slipping and I am unable to tighten it up. I pulled the whole thing out to have a look at it and not matter what I try I can't undo the diff screw. Does anyone know why and have any tips for fixing the problem?
Hi Pete,
Sounds like the little diff nut is stripped.. Has happend to me once with a different Losi kit. See if you can see the nut turning as you undo it. It more than likely the plastic cage that the nut sits in has stripped the little locating lugs that sits in the slots of the out drive cup.
Mark..
