Tamiya TA05 IFS
#572
Order from this guy. It comes from Japan and will get here in less than a week. Also his prices are the best and postage is CHEAP!
http://cgi.ebay.com/Tamiya-DB01-Fron...3286.m20.l1116
#573
#574
If he doesn't have something you need
This guy might http://myworld.ebay.com/vellrip&ssPa...MEFSX:SELLERID
#575
I've ordered from him a few times, fast shipping.
http://www.vellrip.com/store/home.asp
#576
One more question as I just finished the build of my IFS-R. The directions call for a 13.5mm space on the push rods, however if I leave them this way the car is WAY too low to run (drags). To make this work, I adjusted the push rods to a point where the space is now 17mm. Does this seem right or did I do something else wrong. I've rechecked my work a number of times and can't locate any other area that seems to need attention. I've built a number of kits over the years, but this is my first IFS.
PS - In regards to my previous post regarding the 37T pulley. I carefully reamed out (with a body reamer) the center hole on the 37T diff pulley and it fits perfect in the spool (screws lined up perfectly). Thanks to everyone for the additional sources, but it seems this will work for now while I await the correct pulley.
#577
Altering those spacers is like moving the damper to a different position on the control arm. Not so much for adjusting ride height...
#578
Is there anywhere I can download the manual for the IFS-R? I can't find it in any of the usual places...
Really what I need to know is what bearing sizes I need to replace the bushings in the steering. 4 x 850? I am ordering the 53993 rocker set which comes with bearings so that part is covered.
Also, what's the internal ratio so I can order gearing at the same time as I order the kit?
#582
IFS or IFS-R
I am trying to cut costs and have an opportunity to buy an TA05 IFS NSX 2007 kit for $160 ( closeout pricing ). The best deal I have found for the IFS R version is $230. The obvious differences between the two ( with regard to cost ) is the IFS comes with a body and a silver can motor ( basically another $50 in savings because I need both the body and 540 motor. The difference $70 + $50 = $120. My goal is to race this car in TCS regionals this coming year so I am wondering what specific hop up parts are thought to be essential to making the IFS competitive( and sturdy) with the IFS-R , then I can compare the cost difference. I don't really know all the specific differences between the two models so any help would be appreciated before I have to make the decision of one or the other.
note: I have read almost the entire thread and nothing was conclusive about upgrading the IFS to an IFS -R.
#583
#584
I just found a partial list of the differences between theTA05 IFS and IFS-R
http://www.tamiyausa.com/product/ite...oduct-id=49491
Innovative TA05-IFS chassis features inboard front suspension with horizontally-mounted oil dampers for accurate depiction of low nose body.
Front and rear reversible suspensions provide excellent handling and precise suspension adjustment.
Impressive list of option parts to be included (tentative list):
New center plate
53988 Ball Differential Pulley 37T (for front and rear)
53989 Center Pulley 18T
New front/rear drive belts
53991 TA05-IFS Carbon Reinforced N Parts
53895 TA05 Cargon Reinforced K Parts
53894 TA05 Carbon Reinforced A Parts
53869 5mm Aluminum Short Ball Nut (Blue)
...and many more
R/C system, ESC, battery pack, body, motor, tires, and pinion gears sold separately.
#585
