Crankshaft wear
Crankshaft wear
Just wondering whether other people get crankshaft wear similar to the following:
My piston and sleeve is fine no sign of wear there and the engine is perfectly clean otherwise. Just some scuffing around this area. All of my engines have a similar thing on them.
have you ever overheated your engine or leaned it out to much?
what kind of engine, and what kind of fuel?
The scoring that you see is from dirt..... check your front bearing also...........
I have never noticed them before, not sure whether others get similar wear patterns.
hmm.... have you ever over reved the engine?
ooo, well i guess if you havent been having any problems so far then it should be fine, just remember to put after run oil
it might be just the way they mill it
AMG, i just took apart a 21 with over 2 gallons in it for some major cleaning and havent noticed anything like this. Ive taken apart several engines in the past and havent seen this before. by the way, if something like dirt or shavings exists in your crankcase it doesnt have to neccessarly enter the with the fuel flow to your piston conmustion area but just hang around below your piston and thus you dont see scaring on the piston/sleve. just brainstorming. interesting indeed.
Originally posted by AMGRacer
Rody 5 port motor with RB concept fuel.
the inlet that the carbie fits in may have had a bit of a bur or somthing at the base and it was scrubbin on the crank ?????
