Black Water-ish Liquid? >
Old 04-11-2003, 10:50 PM
Default Black Water-ish Liquid?
There is this black water-ish liquid going all over my chassis and I have no idea what it is. Can someone help me?
AtomiK is offline
Old 04-11-2003, 10:54 PM
dont worry its just oil, dont worry make sure you have a gasket between your manifold and engine
buggyman81 is offline
Old 04-11-2003, 10:56 PM
What is a gasket?
AtomiK is offline
Old 04-11-2003, 11:45 PM
sausage_link's Avatar
it is made of gasket paper and seals off the parts where the manifold and engine connect.
sausage_link is offline
Old 04-12-2003, 10:26 AM
RedScorp's Avatar
Default Re: Black Water-ish Liquid?
Your motor should have come with a gasket to sit between your manifold and the engine. If the motor has been used a lot and the gaskets are getting old, you can ask your LHS for a replacement.
Generally speaking you'll be fine but if it bothers you, go to your LHS and purchase the gaskets and replace them for peace of mind. But, a oily chassis is just part of running Nitro. As long as it isn't excessive amounts of oil then you're fine. Just make sure you strip the car down and clean it frequently.
RedScorp is offline
Old 04-12-2003, 10:47 AM
What are the gaskets made of and about how much should they cost?
AtomiK is offline
