Which discharger is the BEST?????
I am currently looking into buying an individual cell discharger,but am really confused what to buy.I had read people have problems with the much-more ones and I thought that would be the best.Please let ne know about your dischargers and what u guys recommend.Thanks for all the info and tips everybody.
i have a mm and no probs with it
the trinity dpd works ok as a discharger but dont match with it.
From what I understand, you want to discharge at a similar rate as driving on the track.
That said, I was discharging with my Intellipeak charger @ 10A and my Ice also @ 10A, maybe a little low for good batt health.
I have recently purchased a Trinity Zero-30 discharger. After using it for a few weeks and agressively cycling all my batts, I have really noticed a modest performance increase in the cells.
Discharging @ 30A constant, would seem to be the best way. I currently have several other threads looking into a battery re-matcher. I currently run 4 cars out of my pit box and next season anticipate running six! (darned kids!) So, I want to have the capability to keep the batts in prime shape for the next upcoming season.
If my threories are askew, please chime in...
Allan
Allan
I had two CTX-D's ver 1's, both had problems and needed to be sent back to Much More for repairs, I also never did trust the readings they gave, so I sold them both and recently purchased a Trinity DPD. I have not had a chance to use the Trinity DPD yet.
What I liked about the CTX-D's were the 30amp pulse discharge, the 5amp linear discharge and the adjustable voltage cut-off. These features kept the batteries cool during discharge, worked well to equalize the pack before charging and kept my packs performing well as they aged.
My hope is the Trinity DPD will do those three functions well, without having to worry about it having to be sent in for repairs, in addition the battery power feature can keep clutter at the pit table to a minimum.
I also have a Integy Zero 30 discharger, it works well for bringing down packs quickly, but the heat on the batteries is rough over the long-term, since switching to the pulse dischargers I have noticed better performance from my newer and older battery packs. I keep my Zero Thirty for emergency purposes only.
Bottom line, a 30 amp pulse discharger with voltage cutoff would be my first choice, if the Trinity can do the job at half the price of the MM CTX-D then that would be my recommendation, in the coming weeks I will be able to report on the performance diffenences between the Trinty and Much More products. Hope this helps.
R/C Tech Elite Member
I've read that the DPD takes a very long time to discharge a pack, up to 2 hours in some cases because of the pulse and trying to minimize heat. While discharging at 30 amps is good for your packs isn't discharging that slowly a downside? If so does the benefit of discharging at 30 amps outweigh the time it takes?
mine takes about 40 minutes to discharge 4000mh
If a 5 minute race discharges a pack and creates heat, then why is it so terrible to complete the discharge at the same rate? I can bring a cooled down pack from a race down to no lites on the discharger in 3 to 5 minutes, ten minutes tops with my 4200s. Then its off to my equalizer tray.
Are we talking two different processes here?
The battery doesn't know if its in a car or in a discharger...cycling a batt is a completely different process.
Allan
Allan
Originally Posted by GymBeam
if the pack takes 2 hours on a dpd then they prob have a dead cell or very poorly matched pack
on 1 of my 3700s practice packs (battery no longer matching as well) .. it can take up to 2 hrs or more. on my matched 4200s, it will discharge it around 40 mins ..
Once a weak battery in the pack reaches the cut-off rate, the DPD will discharge the whole pack at a much lower rate.(can’t remember .. was it 0.5A? hence taking a much, much longer time).
