gearing on a mf2 losi
what kind of gearing do you run on your mf2 truck?
i seem to burn up stock epic motors with a 16 tooth and i geared to a 20 and burnt one up.
just looking for what you run
set up on mine is step pins and 86 tooth spur gear
I'm running a 21t pinion with a 19 turn motor with no problems, even during 8+ minute practice sessions. It does help that the track is a balmy 40f.
its 5 min races the motors seem hot with 20 tooth but and 18 tooth the 16 on the motor i was running was much cooler. but i was tolt im way to low geared
it could be the motor is just powerfull at bottom end i guess and likes the lower tooth.
I run 16/86 with the purple top handouts, and usually a 18 on pk2's...
It depends alot on your track on how the motor will need to be geared to keep it in the right temp range.
16/86 and 5mins i come off at @120-130, i try not to get em much hotter cuzz budget racing sux
