Tamiya TA05MS
#633
how many holes should i use? oil wt?
#634
It all depends on how much traction is available. You need to tune based on that.
Dampening plays a large part in how quickly the suspension will compress and decompress. If you use the same shock oil, less holes=slower moving suspension, more holes=faster moving suspension.
But there's also the issue of "pack" which I don't understand completely; I don't even know how applicable it is to rc touring. Maybe someone can enlighten us on the topic.
#636
#638
is the 1k spool is for 05ms? im planning to get one.
#639
You could always make your own spool with an old differential and some epoxy.
I think the JRX-S kit came with some sandpaper discs that you could use to make a temporary spool with the stock diff.
I have the regular TA05 spool and the only difference to a "homemade" spool is that it's all steel which is hard on the driveshaft pins.
#640
about the ta05 spool, is i a direct fit for 05ms except its not wide pitch?
#641
Yup, it fits right in.
#642
http://www.tamiyausa.com/product/ite...oduct-id=53936
#643
thank you guys.
#644
Quattro is right. I've been using the wide pitch one-way pulley on my spool.
#645
