Like Tree1Likes
Mugen MTX-4R
Old 09-19-2007, 08:08 PM
  #481
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by wallyedmonds
the r comes with cv's
and the r car comes with tie pillow balls and alm hex's for the wheels.
i got the mtx 4 and i had to use the balls and hex's from my mtx-2 ya there that old and still good.
I wish it came with a 4 mm chassis
Then there wouldnt need to be any upgrades.......
Any other upgrades needed? Im getting a list together of what I need to be a nitro tard lol..... It was just to much fun
BlackedOutREVO is offline
Old 09-19-2007, 08:21 PM
  #482
wallyedmonds's Avatar
if you like try to get a kanack 4mm chassis but the kawahara is very nice.
wallyedmonds is offline
Old 09-19-2007, 08:26 PM
  #483
How much are they?
I need a list of EVERYTHING you guys would do or want
I mean I will get the most important stuff first, But all the little things will get bought eventually......
Top things on the list is the 4R and the MR12 Ninja with the pipe and header
Old 09-19-2007, 11:02 PM
  #484
Roger's Avatar
Everything you need is in the kit. My car is completely stock and so are alot of drivers that use the MTX-4R in our area. Don't worry about what you think you need to be any faster. Your main focus is to get a MTX-4R, build it, and practice, practice, and more practice at your local track ( SpeedWorld ). Once you get familiar with the car and its driving characteristics, then you can make decisions on what to get ( IF NEEDED ). But, truthfully, the car is dialed out of the box.
Car fully rebuilt:
Roger is offline
Old 09-19-2007, 11:09 PM
  #485
Roger's Avatar
How simple is it to strip 2nd gear?
Are we talking a bit hit that breaks part, or a wall tap???
I have heard alot of stripping 2nd gear reading the threads around here
It's not simple at all if you know what you're doing. I've helped many mugen users in our area about this so called " Issue ". Roenz ( baby serafin ) at VRC raceway stripped afew gears at his track, but after I showed him what was happening and what to do, he hasn't stripped a gear ever since . If you need help, let me know and I can show you. Get you kit first though
Roger is offline
Old 09-19-2007, 11:11 PM
  #486
asw7576's Avatar
Originally Posted by Roger
Everything you need is in the kit. My car is completely stock and so are alot of drivers that use the MTX-4R in our area. Don't worry about what you think you need to be any faster. Your main focus is to get a MTX-4R, build it, and practice, practice, and more practice at your local track ( SpeedWorld ). Once you get familiar with the car and its driving characteristics, then you can make decisions on what to get. But, truthfully, the car is dialed out of the box.
Mine is bone stock, except : longer titanium screws, front CVD and alluminium lower suspension arm holder ( kawahara ).
Always start with original setup manual as starting point.
asw7576 is offline
Old 09-20-2007, 02:31 AM
  #487
rmdhawaii's Avatar
Read the "Stripping 2nd gear?" guide at my Web site and you'll be well informed about the issue.
If you take a hard hit, there is always the chance that the engine will move. That applies to any car.
Stripping gears is just a part of life. Everyone has a stripped gear now an then. Screws come loose, things wear, the engine shifts - anything is possible. If you take good car of your car, you reduce your chances for any problems.
On upgrades, Roger is right. You don't need to add anything to the "R" performance wise. You may want to consider getting (1) the original uprights (T0138-B), as the car drives slightly differently than with the newer uprights (T0164), so you can see what works better for your driving style, (2) the one-piece engine mount to reduce your chances of stripping a gear and (3) a front diff to run on tight technical tracks.
Hope this helps.
rmdhawaii is offline
Old 09-20-2007, 09:11 AM
  #488
Car Breaker's Avatar
if yours is a "R", just need to build the front Diff, get T0138-B, thick shock tower and one-piece engine mount if you have trouble fitting your engine on stock engine mount like me,
alway mesh the gear slightly tighter, DO NOT use paper method. I run my car for whole year, hitting polls, walls, and have other car hit me at the engine shaft, no problem at all
Car Breaker is offline
Old 09-20-2007, 09:41 AM
  #489
spenzalii's Avatar
How does the car drive with the different uprights? Is one more agressive on turn in?
Also, anything definite on the 4mm chassis/one piece combo that works and doesn't work?
spenzalii is offline
Old 09-20-2007, 10:39 AM
  #490
R/C Tech Elite Member
JayL's Avatar
completely stock eh Roger, wish my car came with ti scews and rear CF shock tower brace, hehe
Listen to Roger! He got my car shifting perfect as well, never one strip. You might want to look at what engine he runs as well
JayL is offline
Old 09-20-2007, 01:09 PM
  #491
ya its an over priced jp mod im thinking out loud again
Old 09-20-2007, 01:12 PM
  #492
yes the different uprights make the car turn or corner better depending on the track.
and if you want a non slugy car the 4mm chassis is a must the 1 piece motor mount helps but the chassis is a much better thing.
Old 09-20-2007, 01:23 PM
  #493
Roger's Avatar
Did you ever get the parts I sent to ya ?
Yeah, an overpriced JP that I got practically got for free Im still waiting for my ninja motor Wally .
Roger is offline
Old 09-20-2007, 01:25 PM
  #494
YBSLOW's Avatar
Roger you have PM.
Brad
YBSLOW is offline
Old 09-20-2007, 01:42 PM
  #495
Roger's Avatar
Thanks. Right back at ya bro.
Roger is offline
