Mugen MTX-4R
#3616
looking for a bit of advise if possible, i can't seem to keep the rear of my mugen planted. pretty much anytime off throttle the rear comes loose, a fellow racer loaned me purple rear springs, was blue. and a 2.5 rear sway bar, was 2.3 and it help alot but still not stable. 60wt mugen oil all around, -4 degree rear camber, 100,000 wt. front diff oil and 30,000 wt. in the rear. droop 3mm all around if i remember correctly. measured at the lowest places of hubs.
Try This:
droop= front 1 rear 4
camber= front 2 rear 4
toe in = 3
toe out=1 each side
2nd to lowest hole for rear shock position
24tooth side pulley 2 1/2 split on tires
Let me know how it works out
#3617
#3619
hi all..i`m new here have couple question to ask.. now i`m using original 4r clutch..i prefer to chance new clutch which more lite and power seems like power clutch..which one clutch set that you guys prefer to use?
4r diff were big compares to another latest brand rc cars, have anyboby tried to change another brand diff or option diff?
thanks...
thanks...
#3620
thanks...
thanks...
#3622
thanks guys..i`ll go to change light weight bell and feel the different first
roadrash, u still using ABI wasp engine? ur comment bout this engine coz i have 1 and will running in tomorrow
#3623
great motor when u run it in get it goin a little rich and run it like u stole it get the temp to 200 or so shut it down let it cool off and repeat for about 4 tanks of fuel and you'll be good to start tuning for race when u start to lean it out make very small movements, factory settings r very close to a good tune. these motors dont need a long break in process like other motors ive ran a gallon through mine and it keeps getting better, i love it ive got the temp up to over 300f on accident with no ill effects the motor still looks new inside if u need any advice about it send me a pm
and have fun youll love the mugen its a great car i get my first chance to run the capricorn on sat its got big shoes to fill as far as im concerned
#3624
thanks roadrash, nice to know u many input to learn i`ll pm u if i have any question bout this engine..
yes, still love it after 3 years drove my 4r, just changed new chasis it`s still competative car compare to others.. i heard that mugen will come out new model MTX-5..is it true?
#3625
rear shock tower
I have a quiestion:
today during my main the rear shock tower go off the car, don't broke just go off,is the second time that happens to me, I am using 4mm rear shock tower, i change the plastic that hold the shock tower(covers the rear diff) and it happens again today any idea? I am using the screws that the 4mm shok tower have in the pack.the last time that happens and today the track conditions were bad and i was using stratus body, usualy in good conditions i ran with altis 2.3 or audi but when is cloudy or the traction is bad i ran with stratus, can it be the body???...
#3627
Use longer screws, 3x12 or 3x14.
#3628
I know is wierd, I am running 4 since 2005 and i change to 4R on 2007 and change the kit for anew one on 2009 and allways use the 4mm rear shock tower with the 3x10 stock screws that comes un the pack of the shock tower, I'll move to the 3x12 or 3x14 with thred lock
#3629
what is d best diff oil to use? mine now 30,000 wt front and 20,000 wt rear...
also front upper arm spacer and rear roll centre holes.. especially for small technical tracks with medium traction..
thanks..
thanks..
#3630
I go with 10k front, 30k rear, light blue or dark blue springs ( mtx3 springs ), 35 front and 37 rear foam tyres, 3mm tire split.
