Mugen MTX-4R
#3286
hey guys i pulled my car apart after a club meet and crossed check everthing top to bottom, the only thing i found really needing replacement are my body posts front, and rear lower arms as there is some slack back and forward starting to happen - pretty impressed with the overall road bust of the Mugen, just one thing any of you get sometimes clicking of the drive train from time to time, is this wheels done up tooooooo TIGHT? or are bearings on the way out?
I have decided to stay with the SPOOL and not front diff
#3287
for the bodyposts I find running a CF brace between them really helps
#3288
Mugen Internal Ratio
Hey guys, for those of you that have adapted a Serpent or Kyosho transmission to your cars. You will probably notice that these two brands (S and K) have their transmission set for a lower gear ratio, as low as 2.
A Mugen car has a ratio of 2.158 and as you will probably notice, you will run out of top speed in fairly average size tracks.
Two pulleys need to be changed in the internal ratio in order to bring it lower.
In my case, I changed it from 2.158 to 2.05.
What you need is:
-20T Brake Pulley
-19T Rear Side Pulley or 23T Front Side Pulley (These pulleys are the ones that run on the side belt, you need to change ONE not BOTH)
Here is a few options you have:
For the Brake 20T pulley
-Mugen MRX-4X pulley can be adapted no problem
-Team Titan or Zepping 20T Aluminum Pulley can also be used
-Xray NT1 has a 20T brake pulley, but you may need the NT1 brake adapter and possibly use a NT1 rear belt due to width. (Never tried this one myself)
For the Side Pulley
-MTX-3 Pulley set has the 23T and the 19T pulley
-3Racing makes an aluminum 23T pulley
Inconveniences with belt tensions
From 19T to 20T (Brake Pulley)
You can resolve this two ways:
-You can use a Kyosho Rear Belt which is 1 tooth longer
-Or you can get Serpent's Aluminum Eccentrics which allow the Diff to sit higher and forward in order to lower the tension. Other modifications to the Rear diff cover need to be done in order to have a smooth run. In my case, I only have one belt tension set which is having the eccentrics tab completely backwards.
From 18T to 19T (Side Pulley) (Option 1)
-Mugen Belt is really really long, longer than it should be in my opinion. So using a 19T side pulley presents no inconvenience to the belt as this can be adjusted using the Belt tensor.
From 24T to 23T (Side Pulley) (Option 2)
-This might present a problem, because it means the belt will be very loose. I have not tried this one myself yet, but if any problem arises, Kyosho's side belt is 1 tooth less than the Mugen Belt and will probably fit there.
What you need is:
-20T Brake Pulley
For the Side Pulley
#3289
What you need is:
-20T Brake Pulley
For the Side Pulley
What you need is:
-20T Brake Pulley
For the Side Pulley
I know some guys just went with a K 2 speed to line it up better with the Capricorn clutch... I put the Capricorn clutch and simply used the mugen 2 speed....
#3291
What you need is:
-20T Brake Pulley
For the Side Pulley
What you need is:
-20T Brake Pulley
For the Side Pulley
What is the reason for putting the K or S transmission in the Mugen?
#3295
On my MTX4, I found out why I am having the stripping issue with second gear. The bearing in the 2nd gear housing was hanging up, thus causing the strip. When I put a new housing on with a fresh bearing, the stripping stopped. Upon examining the last one, I put it on an old shaft from my MTX3 and spun it; it did not spin freely. Word of advise, clean and lube it after a few runs for those that don't clean this bearing and see if that stops the stripping issue (if the gear is meshed right). I am going to see if the bearing can be punched out and replaced with a better on (possibly ceramic).
#3296
It is a direct fit. All you need is the complete shaft with the spurs, bearings, 2-speed. You need to cut out a portion at the other side of the shaft, and make a flat part in order to secure the side pulley. Also, you need to elongate the size of where the brake pulley's screw sits.
You will need to make a spacer for the shaft that goes in between the bulkhead and the 2nd gear bearing.
I also used the complete 720 WC clutch.
This Friday I may post the measurements of said spacer and how to cut the shaft.
#3297
+ YouTube Video | |
Local Club meet random footage of spills, crashes and some close racing - pardon on the footage the missus was filming while me in the PINK "MTX4R" was racing......
Enjoy the random footage of what we get upto at Littlehampton Raceway ib South Australia on any given Sunday!
Enjoy
Frank
#3298
+ YouTube Video | |
Enjoy
Frank
Nice Video Kodak, I can't wait to run my sedan again. I just need to break in a motor....
#3299
I don't have to use snake or "k" tranny , I use stock tranny and capricorn clutch and good mesh setting and do not strip spurs !!!
on the nats I use the used spurs (the old black) and still using the same here on P.R. ha!
#3300
What you need is:
-20T Brake Pulley
For the Side Pulley
What you need is:
-20T Brake Pulley
For the Side Pulley
