Like Tree1Likes
Mugen MTX-4R
Old 07-26-2009, 06:43 AM
  #3166
Good day gents.
New Mtx 4r owner here.. Im relatively new to the nitro scene, so take it e-z on me, I have a chance to get a Ninja mr12-T01 kit for a nice price, or should i go with the Nova 353 09 , 2630 pipe, with small manifold combo.. Just looking for the best bang for buck,
thanks in advance
Nupe05 is offline
Old 07-26-2009, 08:17 AM
  #3167
Originally Posted by Nupe05
Good day gents.
thanks in advance
infernoman2008 is offline
Old 07-26-2009, 07:13 PM
  #3168
Damnit Man's Avatar
Default Dumb question
I just got a MTX4R and found that the front wheels only turn once compared to 2 turns from the rear wheels. Is this normal? Also why is it that on the Mugen set up sheets from team drivers, am I noticing 2 different diameter sizes from left to right on tire size? Would this mean that they were countering for balance or the amount of left or right turns in a race? I bought the car used so I have no manuals for the car except for the one I downloaded from their site. I am experienced in electric touring car racing, but this nitro stuff with foam tires is weird to me.
Damnit Man is offline
Old 07-26-2009, 08:21 PM
  #3169
Riketsu's Avatar
Trader Rating: 34 (100%+)
Recheck all your pulleys to see if they havent been changed.
I'd suggest using the 24T pulley in the outside middle shaft instead of the 25T. I believe with the 25T, you would need almost identical tire sizes whereas with the 24T, you can use a 2mm split.
Riketsu is offline
Old 07-26-2009, 08:36 PM
  #3170
Damnit Man's Avatar
The front center belt pulley is a 24 tooth and the rear center pulley is an 18 tooth. By split do you mean run a taller tire in the rear than in the front to compensate for rear tire wear and what I think may be called "overdrive"? Why wouldn't you want everything equal?
Old 07-26-2009, 10:44 PM
  #3171
Kodak Hodak's Avatar
hey guys what benefits in using a front diff to a solid oneway?
my car is going strong and i seem to be improving each race meet on a fairly stock setup out of the box.
I see some of my club members using a DIFF and not sure what the benefits can be?
doe sit give more steering os it is a bit better on front belts and drive train?
cheers
Frankie
Kodak Hodak is offline
Old 07-26-2009, 10:49 PM
  #3172
keavze's Avatar
cheers
Frankie
front diff will stress the drivetrain lesser and kinder to the belts.
it'll also give you slightly more turn-in but out of corner punch will be reduced slightly.
keavze is offline
Old 07-27-2009, 06:17 AM
  #3173
sohlman's Avatar
Trader Rating: 92 (100%+)
...and it gives you incredibly smooth and effective braking. Definitely a "late-braker's" dream set up.
sohlman is offline
Old 07-27-2009, 11:25 AM
  #3174
asw7576's Avatar
Kodak Hodak:
If I see the video of your home track, I think one way is still the best.
asw7576 is offline
Old 07-28-2009, 07:32 AM
  #3175
Originally Posted by asw7576
Kodak Hodak:
yeah i spoke to another person and he too thinks oneway is good.. the only issue i have is whats best to save on wear of the plastic gears and belts?
currently i am running a 2mm split
Front 61mm
Rears 63mm
Old 07-28-2009, 08:04 AM
  #3176
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Front 63mm
Rears 61mm
fronts should be 2mm smaller
Pattojnr is offline
Old 07-28-2009, 09:36 AM
  #3177
JRGTR's Avatar
Front 63mm
Rears 61mm
are you soure about this tire diemater???
the rears don't last the main and the car will be looooooooseeeeee!!!
JRGTR is offline
Old 07-28-2009, 10:07 AM
  #3178
asw7576's Avatar
I think it's a typo error, I guess kodak wanted to write :
61mm front
63mm rear
For my self, ( my hometrack is quite abbrasive this year )
62 front, 35shore
65 rear, 40shore
asw7576 is offline
Old 07-28-2009, 11:58 AM
  #3179
stefan's Avatar
Has anybody built diffs with ball bearings for the outdrives?
You should. gets you one heck of a smooth diff..
stefan is offline
Old 07-28-2009, 01:00 PM
  #3180
Riketsu's Avatar
Like serpent? Can you post pics and the size of the bearings???
Riketsu is offline
