Mugen MTX-4R
#1502
RE; chassis
Thanks for the info
Joe
Joe
#1503
mtx4r
SOLD
hi guys i have a mtx4r for sale with a lot of xtra parts and hop ups
i'm from the philippines but willing to ship anywhere.
Mugen MTX4R very good condition w/ spare parts and option
B/N JPRacing FX12-03T w/ bnew novarossi 2601 inline pipe
specs:
with JPracing FX t05 modified engine/tsais polished pipe
B/N xtra JPracing fx12-5 ports piston/sleeve and conrod set
futaba 9451 servos
full mugen titanium screws upper/lower
proline dodge stratus cover
venom 1200mah rx battery
JR 3 wire switch w/charging plug
bnew grp foam tires
3racing aluminum handle post
3racing aluminum front center bulkhead for pulley
3racing aluminum brake arm
3racing carbon battery tray
3racing aluminum pulleys
included parts and options(bnew still in package)
2pcs T0267 side belts urethane
2pcs T0266 rear belt urethane
T0268 front belt urethane and rubber
1pc T0255 2nd gear 55t
1pc T0255 1st gear 59t
2pcs T0732 pinion gear 17t
2pcs T0729 pinion gear 23t
1pc T0277 front diff cup
3racing aluminum front bulkhead shock tower
3racing aluminum rear bulkhead shock tower
3racing aluminumrear lower arm mount
3racing aluminum front upper suspension arm mount
1pc mugen mtx4r sticker
selling evething for $500 w/out shipping
specs:
futaba 9451 servos
bnew grp foam tires
#1505
specs:
B/N JPracing fx12 piston/sleeve and conrod set
futaba 9451 servos
bnew grp foam tires
note:i will include the amb personal transponder!
specs:
futaba 9451 servos
bnew grp foam tires
so u have one or two motors, and pipes
radio equipment included?
#1506
mtx4r
yes,extra new engine and pipe is included.2 futaba 9451 servos..no receiver and radio.
#1510
yeah post back on the 4mm chassis, I want one since 301 is my home track and so high traction, kind of curious if it would help. Althou I have yet to race my 4r there yet due to such a busy schedule and racing 1/8 buggy also. One more thing, how are you liking your red dot compared to your ninja I see in your signature
#1511
well i havent raced it yet, sunday will be the truth teller. its the stock red dot not the evo 3 or tuned. but i hope its a good one. great reviews on it and the evo and tune came from this model, the ninja was fine but i shold have changed my rod. literally it broke a day before i went to go get the rod.
i never had to change a rod or bearing in any of my other motors before.
the red dot broke in great once i found the right mixture, and it idles great, even from a full throttle. my ninja was always lean after full throttle?
#1512
Hey guys, what diff oil do you reckon i would run in the rear if i was using the lock diff in the front. This is for a tight technical track aswell. i have 30,000 in there at the moment but i don't think that is enough.
Cheers,
Tim Berends
Cheers,
Tim Berends
#1513
Ask group A drivers in that track, and copy the setup they use.
#1514
I am a group A driver, i just wanted some other peoples recommendations thats all
#1515
Oh I see
IMO, I would test using softer spring at front before changing rear diff oil.
FYI, XRAY makes 60K and 80K silicone diff oil
