540motor bearing size?
hi guys, wanted to change my stock 23t motor bushing to bearing.
any1 know wats the exact size of the bearing to change? thx in advance.
umm, a 540 sports tuned motor which is a 540 can has a different sized bushing to that of a stock motor. i suggest just removing the bushings from your 23t motor and measuring the outside diameter, the inside hole diameter and the thickness of the bushing. try VBX bearings, or do an ebay search for a bearing of the same dimensions as your bushings.
