type of diff oil 2 use
running stock frnt & rear w/ torsen center. track is medium size pretty bumby, could some tell me a decent set up on oil. car is a ofna 9.5. ofna site says 7k frnt 5k rear & center. does torsen get filled or just coated ? called ofna they say coat torsen gears w/ light oil. what is light if this is the case/ thanx for help!
Off the top of my head maybe 5 front 5 center and 2 in the rear. Its hard to recomend diff oils without knowing exact track conditions because there are so many factors to consider, but 552 sounds like a good starting point and just make diff changes from there. Normally people dont use torsens because it makes handling a bit erratic. You can try using a torsen diff in the front but normally thats only if the track is smooth. For the inside of a torsen I use any automotive grease, enough to coat everything with a little extra(don't fill it up). hope this helps
thanks for help guys
