New SS13.5 Pro Stock Brushless Motor
#241
Super Moderator
Originally Posted by mazmo
I am considering converting to brushless.
Can the sintered rotor in the new pro 13.5 be replaced with the bonded rotor ?
Some events here don't allow sintered rotor, was thinking of alternating between the two as required.
#242
Originally Posted by Grizzbob
Yes, they are easily interchangable, although there's no real reason to use the bonded rotor, unless your local track requires it(as mine does, so I can practice with the sintered but have to use the bonded one in club racing, & they do check the cars).....
#243
Company Representative
If you need to use a 13.5T motor with the bonded rotor, you could order one of the EX 13.5T motors to be released later this month.
This motor comes with the original bonded rotor, and costs less than the SS Pro version.
Thanks.... I think I'll be buying new BL Pro Stock 13.5 & bonded rotor
#244
#246
Originally Posted by BrainTeased
is this FDR too excessive? is this a large open track?
#248
Out there as usual...
Originally Posted by HarshGuy
Gear it any way you want to Bill ...you're gettin a whompin this Saturday no matter what your FDR is
That being all of 40 must be catching up to you...
#250
Dang ..I scared you into another continent ...impressive
#251
can someone please give me an idea on gear ratio for a very small indoor track ( 40 foot straight ) with the 13.5 sintered rotor
new to brushless and I dont have a clue
#252
It sounds kinda small, between 38 and 40mm is the norm.
I gear mine to wind up about three quarters of the way down the straight.
#253
what is your brushed gearing for the track? I can then work out a b/less one.
Cheers
#254
I normally run at about 8.0 fdr using a monster
#255
Is anyone having thermal shutdown problems with the GTB/13.5 combo in hot areas like GA? Several of the racers in our group today, including myself, had our GTBs shutdown; sometimes after a minute or so and other times after 4 minutes.
Granted today was very hot and humid; track temp was 145F last I checked it. We were all geared in the 4.9 - 5.2 (FDR) range. One of the guys in our group fried his combo; another was never able to finish a run without shutting down.
Just curious if others in similar climates are having similar problems.
