Z12R (#31250) Vs OS 12TZ-3P?
LRP Z12R ENGINE (31250)
VS
O.S. .12 TZ (P)-T 3-Port Turbo (11373)
OS have always been reliable and easy to tune. I have had bad experience with Picco motors in the past with leaky carbs and just not going for 5min without stalling.
The OS is $100 more, but i am after some feedback from other people
cheers
VS
cheers
VS
cheers
VS
cheers
I am guessing the Z12R is the LRP engine which is based on the picco. I have had a Mega Zx12 (picco) and had problems with carbs leaking and i couldn't get it to run for full race distance. I tried an STS carb on it to see if this would make any difference and it was the same result. I don't know if the Zx12 and the Z12R are identical or not though?
As for the OS i have never had anything to do with the Tz, have heard from others they are reliable, but have issues with the conrod if not replaced regular.
Hope this helps...
BB
Also,
Have just located the LRP Z.12R Team Spec 2 Engine
[LRP31201] and have been talking to a friend about these LRP engines. We have come to the conclusion that the Spec 2 is Sirio based and the original Z12R looks more like Picco.
Maybe someone else has more in depth knowledge though
BB
BB
Originally Posted by Bundy_Bear
Also,
BB
BB
First one was Z.12R Team
Then came the Z.12R Team Spec 2
Now there is the Z.12R Team Spec 3
The Spec 3 is the equivalent to the Picco .12 P1R Evo2 engine, from which other engines are made too.
OFNA JLR Red Dot
IDM P1R Evo2
Mega ZX DSII+
Trinity A. Drake
And now there is a new Picco .12 P1R Evo3 recently announced
I have the JL Red Dot and a Picco Evo2 Edo Tuned (factory modified) and have no issues whatsoever. They are fast and relaible as any top engine on the market today. Internally they are completely different to previous Picco's, including the old Mega ZX 12. No carb issues, stronger conrod, etc.etc.
I also have a OS TZR heavily modified as a speed tuned, and my Picco's beat the hell out it.
AFM
Originally Posted by afm
All LRP Z.12R engines are and where manufactured by Picco under LRP specs.
OFNA JLR Red Dot
IDM P1R Evo2
Mega ZX DSII+
Trinity A. Drake
AFM
OFNA JLR Red Dot
IDM P1R Evo2
Mega ZX DSII+
Trinity A. Drake
AFM
Thank you for your feedback. Is the LRP Spec 2 that Bundy is talking about the same then as the original Mega ZX12? I have not seen an Spec 3 available locally, i would just like a realiable easy to tune engine?
You can get the Spec 3 at Tower Hobbies
http://www2.towerhobbies.com/cgi-bin...?&I=LXPRK9&P=7
Or you can get the JLR Red Dot
http://www2.towerhobbies.com/cgi-bin...?&I=LXPRL2&P=7
AFM
Can someone tell me how reliablity and tunable is the new Spec 3, is it really as powerful as claimed, I thought the Spec 2 from what I have seen was pretty fast but the top end was a little weak.
Maybe the persons using it may not have fully tuned it
Hi Rb_Racer
Hope this helps...
BB
Hope this helps...
BB
My dad run something like 20 litres through his on the same conrod before he rebuilt it
And is it better quality than the LRP Z.12R Team Spec 2 Engine?
if you want easy to tune without giving you carb issues, go for OS TZ12...
but if you can get the tune right without carb issues on the LRP, then the LRP will be a faster engine.
i'm trying to decide to go with the LRP Z.12R Team Spec.4 or the OS.12TZ 3p.
or is there any other suggestions in that price range?
lrp spec 3
- faster than O.S. tz in term of low and high speed.
- quality both about same
- have tuning problem with their stock carb. need to use sirio/sts carb for easy tuning.
- lower cost than O.S. tz
- parts can interchangeable with nosram/picco/idm
O.S. tz
- top speed slightly slower than lrp
- very easy to tune
- slightly more exp than lrp.
- can only use O.S. parts
Both the engine i tested with skyline pipe
*above are just my views for this 2 engine!
LRP spec4 will beat the hell out of os tz12 3p if you can get the tune right without carb issues (on the LRP)...
