TEAM BROOD RACING PRO STOCK MOTOR
Can anyone tell me any information about these? I recently purchased one and was wondering if the specs are correct. I have put it in a TC4. Suggested gearing or any other information.
brood pro stock
hello texracer. the can is black. the endbell says epic 27.
Sounds like you have the Trinity based "X" stock...I believe this motor has a ton of RPM but lacks a little in the tourque department. I would gear it a couple teeth lower than a Co27.. we would need to know an approximate track size.
Butter
Butter
hello team butter. i am new to this site. when i answer to you or others, can everyone veiw what has been discussed so far whether with you or others.
Yes it can be seen by everyone. If you would rather talk off the forum, simply click on the PM button located just to the right of the time stamp of the person you wish to speak to in private.
no its just that i wanted to make sure you know everything so far. the motor came with a PRO-MASTER MOTOR CHECK. would it help to give you some information off that
Super Moderator
hello grizzbob. the track is approx- 40x100 feet. 1 straight away 100 feet. the rest is fairly sharp corners.
Try 6.75 to 6.90.....should get you in the ball park. Hope this helps...
Butter
Butter
team butter. i am new to this, so you will have to give me a little more info. i pressume these numbers are the final drive or something. i have a 72 tooth spur gear.
Thats correct. the numbers I gave you are final drive. You take the spur divided by the pinion times your internal ratio (transmission gear ration) and that will give you the final drive.
72 / pinion x Internal Ratio (2.50) = Final Drive
So lets say you ran a 72 spur with a 26 pinion...
72 / 26 = 2.769
2.769 X 2.50 = 6.9225 (final Drive)
Therefore you will probably start with a 25 pinion and adjust from there..
Hope this little lesson helps..
Butter
72 / 26 = 2.769
Butter
butter. how do you come up with a 2.50 internal ratio.
jeff. how do you come up with that.
