Like Tree387Likes
JConcepts Thread
Old 03-23-2015, 05:17 AM
  #8296
PW
PW's Avatar
Originally Posted by Micah123
Just received golds and they came with blue inserts rather than dirt techs. Is that what they come with or did I receive an old configuration? Thanks
There is a transitional phase where some of the truck tires come with blue inserts, but Dirt Techs will be the standard as the blue inserts cycle through.
PW is offline
Old 03-23-2015, 05:47 AM
  #8297
Question how do u u determine if gold compound will be good for ur track? I'm running indoor smooth clay kinda moist.
DIRT DIGGER is offline
Old 03-23-2015, 06:25 AM
  #8298
jonbrown's Avatar
Which compound and tread pattern would you guys recommend for a dusty dirt track, that never really gets a clean line on it?
We've tended to find that a Proline Caliber or Holeshot works ok, but am curious if a Jconcepts tire might be better option.
jonbrown is offline
Old 03-23-2015, 08:20 AM
  #8299
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Not sure what vehicle you're referring to, but on dry and dusty tracks I'd pick:
1/10 Buggy: Splitters or Flipouts, depending on moisture level (Flipouts when it's not quite as dry) as well as Double Dees.
SC: Double Dees and Subcultures.
carcrusher46 is offline
Old 03-24-2015, 04:40 PM
  #8300
jonbrown's Avatar
Thanks, should have mentioned it's for 1/10 2wd buggy, am fine with tire choice on grass or astro but not a clue with dirt!!
jonbrown is offline
Old 03-25-2015, 01:50 PM
  #8301
Does anyone know when the new body for the 22Tm 2.0 is going to be ready for sale? I really want one and the stock bodys that come with the kits are seriously hideous!!!!
bigco66 is offline
Old 03-25-2015, 01:59 PM
  #8302
PW
PW's Avatar
Should be 3-4 weeks, middle of next month.
PW is offline
Old 03-26-2015, 11:53 AM
  #8303
sneako's Avatar
Originally Posted by Wildcat1971
acetone is bad for clay tires. I would just cut the bead or buy new tires
Originally Posted by aeRayls
Cutting is about the best.
However with clay tires I find baking them off was great. There's only a minor smell for a bit, not a big deal. It's best to then dremel off the old glue before remounting.
Thanks for the responses. I'm opting for the bake off method.
Which foams (AKA, PL or JC) would be best suited for 2WD buggy on a bumpy indoor clay/dirt mix track? I run PL M4 Prime slicks with the closed cells that came with the tires. I'm far from an expert driver / tech - I'm not the kind of guy who notices the slightest changes to set-ups and tweaks.
The Primes with the stock inserts fell much firmer than the JC Barcodes with open cells. They fell better to me as far as how much the tire does not compress in my hands when I squeeze them. Any tire & foam insight is much appreciated.
Thanks again.
sneako is offline
Old 03-26-2015, 03:28 PM
  #8304
curious what he difference is between green and gold coumpound. im running on a indoor slick med bite clay dusty track using sticky kicks or liquid wrench tire sauce. what u reccomend?
Old 03-26-2015, 11:05 PM
  #8305
ray_munday's Avatar
If its soft and dusty, Flip Outs are best.
If its hard based but dusty, also try 3Ds.
Compound: Green is best if its damp or soft. If its hard based, try Blue.
FWIW I created a tyre chart for our tracks down here in Australia which may be of interest:
http://www.rctech.net/forum/10587840-post2.html
Good luck!
Ray
ray_munday is offline
Old 03-27-2015, 12:52 PM
  #8306
jonbrown's Avatar
Good luck!
Ray
Thanks Ray, that's very helpful.
jonbrown is offline
Old 03-30-2015, 07:21 PM
  #8307
Does anyone know the length of the fin turnbuckles for the b4/b5? Thinking of putting them on a different car and what to make sure they would work.
RIchie-Peters is offline
Old 03-30-2015, 11:50 PM
  #8308
bigdaddyquale's Avatar
Trader Rating: 13 (100%+)
Default new tires
so did I miss the new 1/10 scale treads? does anyone have pics of whippets and rippits?
bigdaddyquale is offline
Old 03-31-2015, 05:33 AM
  #8309
PW
PW's Avatar
50.5mm
They haven't officially been announced yet, but it should be any day now. You can see a sneak peek of them in Jason's B5 video on our website - Click Here
PW is offline
Old 04-04-2015, 06:09 AM
  #8310
Trader Rating: 9 (91%+)
Default Release date?
When do you expect the B5M/T5M rear ballstud mount to be released, also curious about release dates for the camber and ride height gauges?
msedsp is offline
