JConcepts Thread
#8281
I was just curious if maybe Dirt Webs in orange or red would be a viable solution to indoor off-road for carpet? I hate running PL carpet tires when I exclusively buy JConcepts stuff.... We still have a fair ways to go ground wise before we can head outside to the dirt.
#8282
Have a couple of questions for you guys:
1. You guys seemed to back off on your support of the Shortcourse classes and haven't come out with any new bodies in quite some time (scale bodies don't count in my book since those are geared towards bashers and nobody uses them to race with). Are you planning on any new bodies? That Ford Atlas body would be super cool if it were made into an SC body, love that front end! I'd think you guys would want to support SC since they go through bodies and tires fairly quickly compared to buggies. Last I checked, you guys are in the Body and tire business, so I'd think you'd want to support the class since it's a money maker. It's simple business 101 right there lol I'm hoping with JC's close relationship with AE, that once the B5/B5m based SC's come out, hopefully you guys will come out with some new bodies as well and help reinvigorate the class
2. I ask this question periodically and it still hasn't happened, but I have my hopes...are you guys planning to finally give us Pre-cut bodies? I haven't run a JC body in years on my Shortcourse trucks simply because it's easier to mount my Pre-cut Proline bodies (and TLR Pre-cuts before I switched brands). I know I'm not alone in this, because I talk to people about it all the time at the track.
#8283
Prepping Dirt Tech Insert Update Results
As another guy mentioned. Use a leather punch that you use to put holes in your tires. Put 2 or 3 holes in each of the inner ribs. Flipping it inside out is a huge help.
When I first got the 60mm wheels and tires I tried 3 things:
1. Stock insert nothing done to it. This was too firm for my medium grip bumpy indoor track.
2 stock insert cut. This was by far better for my conditions.
3. Open cell insert. I stuffed a 2.2 open cell insert in there. It actually doesn't feel too bad at all and gave a lot of forward bite. Unless track conditions really suck and grip is really low, I wouldn't run em.
All in all... The 2.2 just plain works better at my home track.
#8284
As a racer, it's really easy to feel like whatever we're most interested in and see doing well locally is strong nationwide, but that's not always the case .
That being said; if the addition of new SCT kits helps revitalize the class nationwide, we will certainly produce new bodies.
Pre-cut SCT bodies are really nice and we would love to offer them, but unfortunately the class isn't strong enough currently for the huge cost involved.
Need to glue up 2 sets of 2.4's with dirt tech inserts. Any updates on results regarding cutting/punching dirt tech inserts?
#8285
Tech Prophet
I ran the cut rib dirt techs at cactus. I ran the same set of times most of the week. The foams help up pretty good. The track was super high bite at first, then dropped off the last couple days. I put a lot of packs through them and the insert really held up well. The cut ribs did seem to soften up the inserts a little, but also flattened the profile of the tire.
#8286
replacing foams - best way to remove tire?
I have a near new set of Gold Barcodes that have the stock inserts. I want to change over to closed cell and need advice on removing the tire from the rim. I've read that using acetone can shrink clay compound tires and I don't want to cut the bead (I don't have a steady hand and am afraid of hacking the tire). I also don't have an old oven to heat the tire with - fumes?
Am I out of options???
Searched and found differing opinions. Hoping posting to this thread might get a response from a company rep.
Thanks!
Thanks!
#8288
Thanks!
Thanks!
I've cut the bead several times and that really is the best option. Using a new blade is most important.
#8289
Cutting is about the best.
However with clay tires I find baking them off was great. There's only a minor smell for a bit, not a big deal. It's best to then dremel off the old glue before remounting.
#8290
Unfortunately SCT is on a huge downswing while other race classes, scalers, etc are exploding. This means all time and resources are focused towards manufacturing product to meet demands. The distributors dictate a lot and I can assure you the manufactures have a good feel for what they should be producing.
Thanks!
Thanks!
#8291
12mm front hex
Does anyone know if the xb4 12mm front hex fits on the tamiya trf503
#8292
what tires would u recommend for a loose med bite hard packed indoor clay track? im running a 1/10 2wd buggy looking for more foward bite
#8293
#8294
Dirt Web Stadium Truck Tires and Inserts
Just received golds and they came with blue inserts rather than dirt techs. Is that what they come with or did I receive an old configuration? Thanks
#8295
Dirt Webs for the SC & ST come with the blue foams.
